printf to LCD 16207
My LCD routine works fine.I used the code from a template file in Eclipse. But i dun quite understand this template file.
Does anyone know how these 2 lines work??
FILE* fp;
fp= fopen(LCD_DISPLAY_NAME, "w");
Am i writing to the internal physical memory of the LCD module?? otherwise where is this file located at?
regards,
Michael
It's C language essentials. You create a pointer fp, which allocates some space in memory. Then You assign that memory space to LCD. Google "C writing to a file"
