Hi Everyone,
I have installed NiosII IDE5.1, but when I compiled any project, the following errors occurred. c:/altera/kits/nios2_51/components/altera_hal/build/system_rules.mk:119: `: No such file or directory c:/altera/kits/nios2_51/components/altera_hal/build/system_rules.mk:119: "c:/altera/kits/nios2_51"`: No such file or directory c:/altera/kits/nios2_51/components/altera_hal/build/system_rules.mk:119: /components/altera_hal/build/gnu_rules.mk: No such file or directory c:/altera/kits/nios2_51/components/altera_hal/build/system_rules.mk:123: `: No such file or directory c:/altera/kits/nios2_51/components/altera_hal/build/system_rules.mk:123: "c:/altera/kits/nios2_51"`: No such file or directory c:/altera/kits/nios2_51/components/altera_hal/build/system_rules.mk:123: /components/altera_hal/build/gtf_rules.mk: No such file or directory But I can find all the *.mk file in the corresponding directory. Anyone help? Thanks in advance...Link Copied
I had a similar problem when direcoty have some space bar character in path name, try to see it.
--- Quote Start --- originally posted by david_cai@Feb 14 2006, 12:49 PM hi everyone,
i have installed niosii ide5.1, but when i compiled any project, the following errors occurred.
c:/altera/kits/nios2_51/components/altera_hal/build/system_rules.mk:119: `: no such file or directory
c:/altera/kits/nios2_51/components/altera_hal/build/system_rules.mk:119: "c:/altera/kits/nios2_51"`: no such file or directory
c:/altera/kits/nios2_51/components/altera_hal/build/system_rules.mk:119: /components/altera_hal/build/gnu_rules.mk: no such file or directory
c:/altera/kits/nios2_51/components/altera_hal/build/system_rules.mk:123: `: no such file or directory
c:/altera/kits/nios2_51/components/altera_hal/build/system_rules.mk:123: "c:/altera/kits/nios2_51"`: no such file or directory
c:/altera/kits/nios2_51/components/altera_hal/build/system_rules.mk:123: /components/altera_hal/build/gtf_rules.mk: no such file or directory
but i can find all the *.mk file in the corresponding directory.
anyone help?
thanks in advance...
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12701)
--- quote end ---
--- Quote End --- illege character " ` " http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
And so? all ok?
I can't find any space bar in the directory path and any illegal character. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif Pls tell me in detail. Thanks very much.- Mark as New
I have almost find the answer throught altera website.
The following if FYI. Problem Why do I receive the following errors when trying to compile my Nios II project: ../app_rules.mk:152: \: No such file or directory? Solution You may receive the following errors when compiling a Nios® II software project if the mount point for the Cygwin toolset is not specified properly. ------------------------------------------------------------- make -s all "X"which cygpath.exe 2> /dev/null`" was unexpected at this time. <Nios II install directory>/components/altera_hal/build/app_rules.mk:152: `: No such file or directory <Nios II install directory>/components/altera_hal/build/app_rules.mk:152: "<Nios II install directory>"`: No such file or directory <Nios II install directory>/components/altera_hal/build/app_rules.mk:152: /components/altera_hal/build/gnu_rules.mk: No such file or directory <Nios II install directory>/components/altera_hal/build/app_rules.mk:156: ': No such file or directory <Nios II install directory>/components/altera_hal/build/app_rules.mk:156: "<Nios II install directory>"`: No such file or directory <Nios II install directory>/components/altera_hal/build/app_rules.mk:156: /components/altera_hal/build/gtf_rules.mk: No such file or directory make: *** No rule to make target `/components/altera_hal/build/gtf_rules.mk'. Stop. Build completed ------------------------------------------------------------- If this error does occur you can specify the proper moint points by running the following three commands from a DOS prompt: mount <Quartus® II Install directory>\bin\cygwin\ / mount <Quartus II Install directory>\bin\cygwin\bin /usr/bin mount <Quartus II Install directory>\bin\cygwin\lib /usr/lib But when I run the mount command in niosII SDK, it told me that command not found... Anyone help? THanks a lot...- Mark as New
The cygwin environment is installed along with Quartus II. To me, it looks like you have a corrupt Quartus II installation. I'd start with uninstalling/re-installing Quartus II.
Best Regards, - slacker- Mark as New
Dear all,
I have solved the problem... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif I would like to share it with all of you. 1. In DOS shell, change the directory as the following path: C:\altera\quartus51sp1\bin\cygwin\bin where the mount command exist. 2. run the following commands to specify mount point for the Cygwin toolset mount <Quartus® II Install directory>\bin\cygwin\ / mount <Quartus II Install directory>\bin\cygwin\bin /usr/bin mount <Quartus II Install directory>\bin\cygwin\lib /usr/lib Be sure that before you can execute the commands above correctly, you should login PC as an administrator. Thanks all the help... David- Mark as New
I have the same problem with NIOS 6.1
Altera can't find the files: C:/altera/61/nios2eds/components/altera_hal/build/app_rules.mk:153: /components/altera_hal/build/gnu_rules.mk: No such file or directory C:/altera/61/nios2eds/components/altera_hal/build/app_rules.mk:157: /components/altera_hal/build/gtf_rules.mk: No such file or directory make: *** No rule to make target `/components/altera_hal/build/gtf_rules.mk'. Stop. Build completed in 1.139 seconds when they are clearly there. I tried the mount command in DOS and it replies "Device or resource busy" I had other later versions of Quartus and Nios on this computer and that could have caused this problem. Have since uninstalled them. I did a repair re-install of quartus and a complete re-install of NIOS IDE but that didn't help. Any suggestions? thanks
