Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
ps/2 mouse problem in nios system
Hi there!
I'm doing 1 small demo : detect the movement and button states from a ps2 mouse in nios system, I use the university IP core. nios build project no error, but when run, the console display nothing. Is the problem in read 3 byte (code c) or the printf function. Have you give me some advice or the code reference (read 3 byte from FIFO).
Thank!
the code below :
# include "altera_up_avalon_ps2.h"# include "altera_up_ps2_mouse.h"# include <alt_types.h># include <stdio.h># include <system.h>
int maxmin(int no, int max, int min)
if(no>max) {no=max;}
if(no<min) {no=min;}
return(no);
int main(void)
alt_up_ps2_dev * ps2_dev;
ps2_dev = alt_up_ps2_open_dev("/dev/ps2_0");
alt_up_ps2_init(ps2_dev);
alt_up_ps2_clear_fifo(ps2_dev);
unsigned char byte1, byte2, byte3, byte1_x, byte1_y;
alt_u8 X, Y, X1, Y1;
int pX=320, pY=240, B=0;
while(1)
alt_up_ps2_read_data_byte(ps2_dev, &byte1);//read 1 byte
alt_up_ps2_read_data_byte(ps2_dev, &byte2);
alt_up_ps2_read_data_byte(ps2_dev, &byte3);
byte1_x = byte1&0x10;
byte1_y = byte1&0x30;
B = (int)byte1&0x07;
if(byte1_x == 0)
{ X = byte2;
pX = pX + X;}
else
{ X1 = (~byte2) + 1;
pX = pX - X1;}
if(byte1_y == 0)
{ Y = byte3;
pY = pY + Y;}
else
{ Y1 = (~byte3) + 1;
pY = pY - Y1;}
pX=maxmin(pX,639,0);
pY=maxmin(pY,479,0);
printf("%d%d\n",pX,pY);
printf("%d\n",B ) ;
return 0;
