i am trying to implement TCP based Chat Programm on Altera ESDK board.
for this i have write a TCP based Server and Client on linux (ubuntu 12.04 LTS) machine and successfully connect them, i am using pthread over there. now i am trying to build same application on nios-ii platform and add the following to "Simple Socket Server" Example. 1. #include <pthread.h> 2. in main program pthread_t myThread; create_pthread( &myThread,NULL, myfunction,NULL); 3. function to be called outside the "simple_socket_server" example void *myfunction() {} after building the code my simple_socket_server example generate a error saying error: 'pthread_t' undeclared (first use in the function) 1. is ptherad not supported by nios-ii ...? 2. is any other way to create thread or parallel programming on nios-ii...? Regards kaushalLink Copied
