Nios® II Embedded Design Suite (EDS)
Support for Embedded Development Tools, Processors (SoCs and Nios® II processor), Embedded Development Suites (EDSs), Boot and Configuration, Operating Systems, C and C++
qsys_jtag_uart doubt
hi,
is it possible to print a series of number in nios 2 console using jtag uart along with nios2+onchip ram.
i am implemented an counter and made it as a custom component in qsys and i am using it
(adder+onchipram+nios 2+jtag uart).
i tried it but it is printing 0.
my c code:::::
--- Quote Start ---
* main.c
* created on: jun 6, 2017
* author: dipin
#include "stdio.h"
#include "io.h"
#include "system.h"
int main()
signed int ans;
ans = iord(counter_interface_0_base,0);
printf("%d",ans);
while(1);
return 0;
--- Quote End ---
" COUNTER_INTERFACE_0_BASE" is the same in my system.h file
my verilog code
--- Quote Start ---
module counter_jtag_check (clk,reset);
input clk;
input reset;
jtag_count u0 (
.clk_clk (clk), // clk.clk
.reset_reset_n (1'b1) // reset.reset_n
endmodule
--- Quote End ---
update:: i am able to print only one number.. ( i am counting from 1 to 65556, but its only printing 52429) so is it possible to print all numbers ?
can anybody please give any solutions???
--- Quote Start ---
while(1) {
ans = IORD(COUNTER_INTERFACE_0_BASE,0); printf("%d",ans); }
--- Quote End ---
i tride above c code also, but it is printing the same value again & again. my clock is 50mhz.
any help is really appriciated .
thanks and regards
If you only have onchip memory then you probably don't want to (can't) use printf - it creates/occupies too much code space. I'm surprised it compiles...
You probably need to use "alt_printf". This creates minimal code, ideal for Nios implementations using onchip memory only. Refer to the "nios ii classic software developer’s handbook (https://www.altera.com/en_us/pdfs/literature/hb/nios2/n2sw_nii5v2.pdf)".
Cheers,
Alex
hi,
i need to print a series of numbers. but alt_printf wont support numbers. so i am using printf.
Anyway i solved my problem. now its printing fine and thanks much for replaying me :)
regards
