12471 Discussions
questions for interrupt register function:alt_irq_register
hi everyone:
the interrupt register function in nios:
int alt_ic_isr_register (alt_u32 ic_id,
alt_u32 irq,
alt_isr_func isr,
void* isr_context,
void* flags)
isr_context is the input argument to isr . isr_context points to a data structure
associated with the device driver instance.
i do not understand what is "isr_context " , so i find some codes from internet:
some people write base_addr to the void* isr_context;
some people write NULLto the void* isr_context;
and nois examples write others.
in my project, i write base_addr, and the interrupt works
what is the meaning of isr_context ?
is it right to write base_addr to it?
thanks,qd0090.
Interrupt function looks something like:
void ISR_Handler (void* isr_context){ *** code here *** }
isr_context is a pointer which gets passed to the interrupt function, you can use it as a data storage.
