questions of customize ip
hi, everone.
i want to customize ip in my nios design, i devide this new component to several sub-components, including several hdl files, rom.
1.how can i add this ip to the nios? i already have the experiment of adding ip that contain only one hdl file, but i do not know how to add a ip with several blocks.
this problem could be solved by combine the sub-blocks into one hdl file, but i want to keep the hierarchy.
[h=2][/h]
thanks!
thanks!
i read the file, but i still do not know how to do.
for example:
my custom ip has a top file, and 2 vhdl files, 1 rom, 1 divider(the quartus' LPM_DIVIDE),
in the "files" tab in the "component editor" of qsys, how can i add the files?
should i add the rom.vhd and the divider.vhd?
this should be correct.
Hi qd0090,
Thanks for the post. I am new to cutomize design.
This should be able to help me out with my implementation.
The document suggested by Taz1984 is indeed useful.
Try this Reference -> http://www.ent.mrt.ac.lk/~pasqual/courses/en2452/readings/making_qsys_components.pdf
Cheers~
Hi qd0090,
Cheers~
