12600 Discussions
"Failed to execute : ./create-this-bsp --cpu-name nios2_qsys --no-make" Error
aakkü
I've been having problems with createing nois 2 eclipse project. I get this error when I try to create nios 2 application and BSP from template: "Failed to execute : ./create-this-bsp --cpu-name nios2_qsys --no-make" . I made a google search there are a lot of people already having this problem. I tried to run as administrator and no change. No special characters in the path, but still refuses to build.
I am using quartus prime 18.0 and windows 10
How do I solve this problem?
I added a screen capture too.
Please advice.
Ahmed_H_Intel1
Hi, Thanks for the sharing. Are you using ALTERA NicheStack? If yes, you must go to the read me .txt file in the created project and read ALTERA NicheStack tutorial to know how to use it https://www.intel.com/content/dam/altera-www/global/en_US/pdfs/literature/tt/tt_nios2_tcpip.pdf https://fpgawiki.intel.com/wiki/NicheStack http://ebook.pldworld.com/_Semiconductors/ALTERA/one_click_niosII_docs_9_0/files/tt_nios2_tcpip.pdf
aakkü
I'm not sure if I am using it or not. I am new to this. How do I check if I am using it or not? How can I disable it?
Ahmed_H_Intel1
Hi, Please go through the tutorial first to know, BTW I see in your screen there is no CPU name, can you share the Qsys design (screen shot) ? I did the smame steps known to create a project and it is working. Please check the following video and PDF. The attached screen shot shows my NIOS II application and BSP from template. https://www.youtube.com/watch?v=gBknFw511s0 https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/tt/tt_my_first_nios_sw.pdf Regards.
aakkü
I tried a lot of different tutorials step by step multiple times, but I still get errors. Now I get different type of error in compilation. I guess we have to solve this first.
I shared the new problem here : https://forums.intel.com/s/question/0D50P00004DAgF9SAL/another-sldhub-error
You posted in this thread as well. Can we first solve sldhub- error?
Thanks!
Ahmed_H_Intel1
I will check and will let you know shortly
Ahmed_H_Intel1
Hi, This shows that the make files are corrupted, I replicated the issue by editing wrongly the setting. Now I see the same error. I am trying to solve the issue without reinstalling the tool (this is based on the files corruption), I recommend you to re-install the tool. Regards,
