12603 Discussions
"No CFI table found at address 0x00000000" with S29GL064A flash
hi,
I get "No CFI table found at address 0x00000000" with my custom board using S29GL064A flash.
this board was working during 2 years.
When I want to program its flash via JTAG (and Nios II), I get the error.
# Programming flash with the project "$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x00000000 --sidp=0x01a03338 --id=1759304877 --timestamp=1223978176 --debug "cfi_flash.flash" Using cable "ByteBlasterII ", device 1, instance 0x00 Resetting and pausing target processor: OK Reading System ID at address 0x01A03338: verified No CFI table found at address 0x00000000 Original contents (after writing 0xF0 and 0xFF to address 0x00000000): 0: 3A 74 01 04 74 04 C0 04 3A 4C 01 9C 04 FC FF 9C :t..t...:L...... 10: 1E FD 3F 9C 3A 24 00 04 3A E4 2E 04 06 24 00 04 ..?.:$..:....$.. 20: C4 FF 7F 05 3A E4 2E 04 06 0F 00 04 3A 8C 07 34 ....:.......:..4 30: 3A E4 2E 04 06 0C 00 04 3A 8C 09 34 26 04 00 1C :.......:..4&... 40: 26 FF 7F 1D 3A E4 2E 04 06 0D 00 04 06 F5 3F 04 &...:.........?. Contents after writing 0x98 to address 0x000000AA: Same after writing 0x0098 to address 0x00000154: 0: 00 04 00 04 00 04 00 04 00 04 00 04 00 04 00 04 ................ 10: 00 04 00 04 00 04 00 04 00 04 00 04 00 04 00 04 ................ 20: 51 04 52 04 59 04 02 04 00 04 40 04 00 04 00 04 Q.R.Y.....@..... 30: 00 04 00 04 00 04 27 04 36 04 00 04 00 04 07 04 ......'.6....... 40: 07 04 0A 04 00 04 03 04 05 04 04 04 00 04 17 04 ................ Contents after writing 0x00000098 to address 0x000002A8: Same after writing 0x98 to address 0x00000055: Same after writing 0x0098 to address 0x000000AA: Same after writing 0x00000098 to address 0x00000154: Same after writing 0x98 to address 0x00000154: Same after writing 0x0098 to address 0x000002A8: Same after writing 0x00000098 to address 0x00000550: 0: 3A 74 01 04 74 04 C0 04 3A 4C 01 9C 04 FC FF 9C :t..t...:L...... 10: 1E FD 3F 9C 3A 24 00 04 3A E4 2E 04 06 24 00 04 ..?.:$..:....$.. 20: C4 FF 7F 05 3A E4 2E 04 06 0F 00 04 3A 8C 07 34 ....:.......:..4 30: 3A E4 2E 04 06 0C 00 04 3A 8C 09 34 26 04 00 1C :.......:..4&... 40: 26 FF 7F 1D 3A E4 2E 04 06 0D 00 04 06 F5 3F 04 &...:.........?. Ignored possible autoselect code 01-7E as no override data present in section Ignored possible autoselect code 0401-267E as no override data present in section Leaving target processor paused
Have a look at the NIOS manual, It talks about override file for CFI flash. But where Can I get it for my S29G064A ?
I tried to search in Forum too.
Have you got a work around ?
Explications ?
Regards.
I am verifying deeply SOPC Builder (CFI Flash, Tsetup, Twait, Thold...tri-stated bus) and Quartus design files (connections, Byte_n...)
I am manually writing an override_S29GL064A.txt with all CFI infos from Flash Datasheet.
I think you should assign the base address of flash as 0x00000000 in SOPC builder that will solve your issue
regards
M Kalaynsrinivas
Thanks for answer. The Flash address base is already forced at 0x00000000.
I think my Flash has its CFI table overwritten by bad commands. Is it possible ?
Hello mmTsuchi,
I think you have a simple hardware problem: it seems that D10 of your data bus has no connection to the Flash. Search for soldering problems and look if D10 is configured to the right I/O pin...
Pin D10 problem because I get "0x04" data ? I hadn't thought before. Thanks you very much for reading, observing, answering and giving the clue (1.5 years after ;-))
I had an oxidation on few boards, I will look at...
