12600 Discussions
"Simple Socket Server" demo code stop after display "simple socket server starting up
Dear Friend's
i am using DE2_115 board and over that i am running simple socket server example, i just strip out LED and 7-Seg Show Task's from my Code and compile it but when i run this peace of code, it stuck after display "simple socket server starting up". nothing else happen afterword.
regards
kaushal
You must write 1 to the edge capture bit in order to clear irq.
Then the correct command in irq handler should be:
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(LOAD_BASE, 1);
Probably the problem is simply here: irq is not cleared, thus keeps on retriggering and your code gets stuck.
--- Quote Start ---
--- Quote End ---
Hello Cris72,
I have do the change as you suggest, but it stiil stuck at same place....no change ...!!
Sorry, I suggested IOWR_ALTERA_AVALON_PIO_EDGE_CAP(LOAD_BASE, 1)
but actually you should use IOWR_ALTERA_AVALON_PIO_EDGE_CAP(LOAD_BASE, 0xf)
since I see you are using all 4 PIO inputs and the previous one would reset only irq for first button.
This must be changed both in irq handler and before alt_ic_isr_register calls.
Let me know if this way it works
Hello Cris72,
I have put IOWR_ALTERA_AVALON_PIO_EDGE_CAP(LOAD_BASE, 0xf) , but still it stuck at same point......!!!
but when i increase the data cache from 8 kb to 32 kb it start working and come up to my code area.
still it is not taking interrupt.
please look at the print screen of my project.
regards
kaushal
i am taking LOAD pulse as an interrupt
