12600 Discussions
real time clock -- how to w NiosII ?
Anyone having a reference design or an idea on how to have a RTC as a NiosII peripheral ?
The considered design shall use an EP1C3 + EPCS1SI8.
Thanks!
Cheers
Franck P.
Hallo Franck,
There are two ways for using a RTC with the Nios. First you can use an external RTC with SPI, I2C, … interface or you can write or use an Verilog/VHDL module. In my current design I will use an external RTC (Epson RTC-8564) with the free I2C interface from opencores (http://www.opencores.org/).
Bye,
niosIIuser
Hello:
I used the BQ4845 from TI. It's got an 8 bit parallel interface which is suitable for my system.
32khz crystal and battery input pin.
so does this make a 3 way to implement a RTC. Just kidding.
Next for me is the time.h stuff from C. I'm scheduling things at sunrise and sunset any where in the world.
Good Luck
George
