regular expressions with Nios
I wanted to use regular expressions with C or C++ for the Nios.
My code gets compiled but the linker gives an undefined reference to regcomp and regexec.
Doe anyone have a clue to solve this issue?
thanks in advance
Did you include all the required headers ( e.g. regex.h, stdio.h, stdlib.h ) ?
--- Quote Start ---
--- Quote End ---
It is not built into the precompiled newlib. That is the reason. For some reason I was even not able to compile it into a customized newlib.
I used http://www.pcre.org/ and built it as a nios library.
regards
