I wanted to use regular expressions with C or C++ for the Nios. My code gets compiled but the linker gives an undefined reference to regcomp and regexec. Doe anyone have a clue to solve this issue? thanks in advanceLink Copied
Did you include all the required headers ( e.g. regex.h, stdio.h, stdlib.h ) ?
--- Quote Start --- Did you include all the required headers ( e.g. regex.h, stdio.h, stdlib.h ) ? --- Quote End --- It is not built into the precompiled newlib. That is the reason. For some reason I was even not able to compile it into a customized newlib. I used http://www.pcre.org/ and built it as a nios library. regards
