hi
hi,i am able to print a set of values to nios 2 consolehttp://www.edaboard.com/attachment.php?attachmentid=140600&d=1502960114&thumb=1 (http://www.edaboard.com/attachment.php?attachmentid=140600&d=1502960114) the values are too large . so need to save the data for further evaluation. how can i do that ? i need to see it i nios 2 console also, is there any options like enable a log file or something ? http://www.edaboard.com/attachment.php?attachmentid=140601&d=1502960320&thumb=1 (http://www.edaboard.com/attachment.php?attachmentid=140601&d=1502960320) like above i can do that , but then its not possible to see it in terminal, when i tried at the same time , the first error came and i stopped nios 2 terminal, then its saving to a text file. and when i try to do it in run configuration,http://www.edaboard.com/attachment.php?attachmentid=140602&d=1502960670&thumb=1 (http://www.edaboard.com/attachment.php?attachmentid=140602&d=1502960670) its not the nios 2 console is saving to the text file, its console is saving to the text file like below.using cable "cv sockit [usb-1]", device 1, instance 0x00
pausing target processor: ok
initializing cpu cache (if present)
ok
downloading 00020000 ( 0%)
downloading 000316a8 (90%)
downloaded 70kb in 0.1s
verifying 00020000 ( 0%)
verifying 000316a8 (90%)
verified ok
starting processor at address 0x00020230
is there any way that print it in nios 2 console and at the same time it will save from nios 2 console? update:: i am using windows 7 thanks and regards
If you want to copy from the Nios II Console and then past to a text editor , you can try this to see if it works...
save printf output from nios ii console: • Currently using Eclipse from Quartus Prime 17.0. Not sure if this works in other versions. • I have not found this documented anywhere, just found it by trial and error. • Prior to clicking the run button, kill the Nios II Console window if it is open. It will re-open when it starts running. • During/after run has executed, select text in Nios II Console window. • Select Ctrl-Insert key combination. It should now be copied to the clipboard. • Paste with Ctrl-v. • This only seems to work once. Must kill window and re-run to do another copy/paste.For more complete information about compiler optimizations, see our Optimization Notice.
