12408 Discussions
selected processor does not support `cpsid i' and `cpsie i' in arm mode.
hi everyone,
i'm new with ARMprocessor and dont know too much about DS-5. just alittle bit from my Softwares >>> SoC EDS 17.1 (from Altera) - DS-5 5.28 and my OS is Windows 10. I am using DS-5 for my SoC FPGA (DE0_Nano_SoC) Altera, which i use Toolchain Altera Baremetal GCC. Nowdays i wanted to use Interrupt for Private Timer and i got error which has conflict with the "alt_interrupt.c" source file from Altera HWlib. And the error appears with > selected processor does not support `cpsid i' 'cpsie i' in arm mode. I read all of the latest Disscusion in Community but didnt help me. I must say, that i manually write my type of cpu(Cortex- A9), type of architecture and etc. but didnt help. i even tried to compile in thumb mode, but didnt help. I thought mybe its a Bug between DS5 v5.28 and Windows10, so i tried it in Linux but i got the same error. When i use to compile another program without interrupt, then everything is fine. the problem might be in these lines >>
ALT_STATUS_CODE alt_int_cpu_enable()
alt_setbits_word(alt_int_base_cpu + 0x0, 0x1); /* iccicr */
/* Unmask IRQ interrupts from current processor. */
# if defined(__ARMCOMPILER_VERSION)
__asm("CPSIE i");# elif defined(__ARMCC_VERSION)
__enable_irq();# else
__asm("CPSIE i");# endif
return ALT_E_SUCCESS;
ALT_STATUS_CODE alt_int_cpu_disable()
alt_clrbits_word(alt_int_base_cpu + 0x0, 0x1); /* iccicr */
/* Mask IRQ interrupts from current processor. */
__asm("CPSID i");# elif defined(__ARMCC_VERSION)
__disable_irq();# else
__asm("CPSID i");# endif
is there anybody, that knows the problem?
