12603 Discussions
serial flash EPCS memory on uClinux (no driver found)
I'm just trying to configure uClinux to manage Altera EPCS controller.
I follow indications as described in alterawiki mtd devices
but the option
[*]altera spi controller does not apear on my menu config.
Also, the files /drivers/mtd/chips/epcs.h, epcs.c epcs_low epcs_map are not present in the source.
I've got uclinux nios2-linux-20090730.tar kernel 2.6.30 from alterawiki
Does anyone know if uClinux support EPCS memory ?
Should I try linux instead uClinux ?
thanks
The EPCS flash is just a standard SPI flash device. I think the Linux kernel supports the EPCS flash using the MTD SPI driver for the ST M25Pxx.
The source code file for this driver is under drivers/mtd/devices/m25p80.c
Thanks a lot Bruce,
I'll try this driver and I'll tell you if I've had success.
By now my hardware is not ready and it may take a bit.
bye! :)
