Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
simple change nios2/s -> /e fails to load pgm
just getting started with de1
i presumed a simple change from niosII/s -> niosII/e in the count_binary
example of the hardware tutorial would compile /load/ run with no surprises
the program runs fine using niosII/s
but if i downgrade the processor nios2/e-the program fails to load-
with the unhelpfull message that appears in the forums over & over
pausing target processor: not responding.
resetting and trying again: failed
leaving target processor paused
at roughly 65% complete ...
.. what am i missing ??
Does the project meet all timing requirements when you compile it in Quartus? The nios2/e core has less pipelining than the /s core IIRC and its fmax could be lower.
--- Quote Start ---
--- Quote End ---
i had tested the both (s&e) at both 50Mhz & 25Mhz
& no - timing had no negatives
The core change can't explain your problem alone... can you switch back to the /s core, regenerate, recompile and test again? Just to be sure this isn't due to a bad pin assignment.
Check also that your two systems have the same parameters (especially reset vector and exception addresses) and use the same clock domains.
I had discovered a 'bad pin' the first time round which got the /s working
moving back to /e the upload still fails - been back and forth a couple time with small tweeks - /s yes, /e no
going to try with the "legacy" tool chain tonight
NOTE: the fpga always installs, just loading the prgm for Nios2 fails
did you compare the reset and exception addresses between the two cores?
if you are using cache memory on the /s core, disable burst accesses, if it is enabled
