http://www.alteraforum.com/forum/attachment.php?attachmentid=9662&stc=1
i used nios II 14.0 in a computer with WIN7 to create a new project, it displays '.sopcinfo does not contain any CPU'? i did create a cpu really! plz help, thank you very much!Link Copied
Are you sure your sopc contains a cpu?
It seems you don't have a Nios II component in Qsys- Mark as New
i have the Nios II component in Qsys in deed, i sure, help!
Do you mind posting your qsys file?
Or at least post a snapshot of Qsys window, showing components and their connections- Mark as New
Have you tried searching the .sopcinfo file to see if the CPU is showing up in there? Perhaps you have a file permission issue preventing that file from being updated when you generate the system.
Topic Options
