12603 Discussions
still struggling with toolchain
I tried to build my toolchain following this thread
previous thread (http://forum.niosforum.com/forum/index.php?showtopic=3129&st=0
and I did the best I could. But somehow I am still stuck at the busybox.
/home/bdu/NIOS/buildroot/build_nios2/staging_dir/bin-ccache/../lib/gcc/nios2-linux-uclibc/3.4.2/../../../../nios2-linux-uclibc/bin/ld: unrecognized option '-z'
/home/bdu/NIOS/buildroot/build_nios2/staging_dir/bin-ccache/../lib/gcc/nios2-linux-uclibc/3.4.2/../../../../nios2-linux-uclibc/bin/ld: use the --help option for usage information
GNU ld version 2.15
collect2: ld returned 1 exit status
make[2]: *** [libbusybox.so.1.1.1] Error 1
make[1]: *** [_all] Error 2
make[1]: Leaving directory `/home/bdu/NIOS/buildroot/build_nios2/busybox'
make: *** [/home/bdu/NIOS/buildroot/build_nios2/busybox/busybox] Error 2
The ld does not support -z option. I guess this has something to do with the patches or configs. But I could figure out which part I missed.
I'd appreciate any help on this.
Hi bdu,
It try to build shared libbb, which is not supported on nios2.
In menuconfig of busybox, disable shared libbb.
It is critical to have the right configs.
Those posts were old. Please follow the new one,
http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174
There is a new build script, and it should be easier than ever.
Hippo
Hi, hippo,
Finally got it working. Thanks for the help! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/laugh.gif
--- Quote Start ---
originally posted by hippo@Feb 9 2006, 01:15 AM
hi bdu,
it try to build shared libbb, which is not supported on nios2.
in menuconfig of busybox, disable shared libbb.
it is critical to have the right configs.
those posts were old. please follow the new one,
there is a new build script, and it should be easier than ever.
hippo
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12651)
--- quote end ---
--- Quote End ---
