hi all
when i add the telnet to my µclunix compilation , i have error lke : telnet.elf2flt(.text+0x1a54): In function `shell': /home/hayder/nios2-linux/uClinux-dist/user/telnet/commands.c:1412: undefined reference to `rindex' telnet.elf2flt(.text+0x1ff4): In function `env_init': /home/hayder/nios2-linux/uClinux-dist/user/telnet/commands.c:1696: undefined reference to `index' telnet.elf2flt(.text+0x2068):/home/hayder/nios2-linux/uClinux-dist/user/telnet/commands.c:1713: undefined reference to `index' telnet.elf2flt(.text+0x31b4): In function `tn': /home/hayder/nios2-linux/uClinux-dist/user/telnet/commands.c:2111: undefined reference to `bzero' telnet.elf2flt(.text+0xadfc): In function `adjust_win_extent': /home/hayder/nios2-linux/uClinux-dist/lib/libg/gtermcap/termcap.c:423: undefined reference to `bcopy' telnet.elf2flt(.text+0xae0c):/home/hayder/nios2-linux/uClinux-dist/lib/libg/gtermcap/termcap.c:424: undefined reference to `bcopy' telnet.elf2flt(.text+0xae74):/home/hayder/nios2-linux/uClinux-dist/lib/libg/gtermcap/termcap.c:405: undefined reference to `bcopy' telnet.elf2flt(.text+0xae88):/home/hayder/nios2-linux/uClinux-dist/lib/libg/gtermcap/termcap.c:406: undefined reference to `bcopy' telnet.elf2flt(.text+0xaeb0):/home/hayder/nios2-linux/uClinux-dist/lib/libg/gtermcap/termcap.c:413: undefined reference to `bcopy' telnet.elf2flt(.text+0xaec0):/home/hayder/nios2-linux/uClinux-dist/lib/libg/gtermcap/termcap.c:414: more undefined references to `bcopy' follow collect2: ld returned 1 exit status make[3]: *** [telnet] Erreur 1 make[3]: quittant le répertoire « /home/hayder/nios2-linux/uClinux-dist/user/telnet » make[2]: *** [telnet] Erreur 2 make[2]: quittant le répertoire « /home/hayder/nios2-linux/uClinux-dist/user » make[1]: *** [all] Erreur 2 make[1]: quittant le répertoire « /home/hayder/nios2-linux/uClinux-dist/user » make: *** [subdirs] Erreur 1 anyone have solution?Link Copied
Topic Options
