12596 Discussions
the problem of compactflash test
yesterday£¬my group produced the slot between compactflash card and up3 board
I first write a test code# include <stdio.h># include <stdlib.h># include <unistd.h>
# include "system.h"# include "sys/alt_alarm.h"# include "sys/alt_irq.h"# include "altera_avalon_cf_regs.h"# include "altera_avalon_cf.h"# include "ide.h"# define ctl_base (int*)CF_CTL_BASE# define ctl_irq (int)CF_CTL_IRQ# define ide_base (int*)CF_IDE_BASE# define ide_irq (int)CF_IDE_IRQ
int cardPresent(void);
int main()
unsigned short usStatus, usBuffer[256];
unsigned int i;
printf("cf card inert or not");
if( !cardPresent() )
printf("error: Compact Flash card not detected.\n");
return -1;
IOWR_ALTERA_AVALON_CF_IDE_COMMAND(ide_base, IdentifyDeviceCmd);
usleep(1);
usStatus = IORD_ALTERA_AVALON_CF_IDE_STATUS(ide_base);
usStatus = IORD_ALTERA_AVALON_CF_IDE_ALTERNATE_STATUS(ide_base);
if(usStatus & StatusRegBitDRQ)
for(i = 0; i < 256; ++i)
usBuffer = iord_altera_avalon_cf_ide_data(ide_base);
else
printf("error: drq not set in status reg\n");
return -1;
for(i=0;i<256;i++)
printf(¡°%04x\n",usbuffer);
if( (IORD_ALTERA_AVALON_CF_CTL_STATUS(ctl_base) &
ALTERA_AVALON_CF_CTL_STATUS_PRESENT_MSK) )
printf("you have insert the cf card");
return 1;
else
return 0;
the result is ¡±you have insert the cf card¡°
ffffffff
fffffff
ffffff
why£¿
then i use the test code on our forum
it only show
nios2-terminal: Warning: Unable to verify whether your download cable is
nios2-terminal: supported for Nios II systems. If you use an unsupported cable
nios2-terminal: you may experience intermittent JTAG communication failures.
nios2-terminal: Please refer to the file errata.txt included in the Nios II
nios2-terminal: development kit documents directory for information on how to
nios2-terminal: update your system.
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "ByteBlasterII [LPT1]", device 1, instance 0
nios2-terminal: starting in terminal mode (Control-C exits)
the design of slot error£¿£¿£¿£¿£¿
