hi every one;
i write my own component in vhd and try to add it in qsys, in the component editor, i and my vhd file and click analyze files, it shows 0 errors and 0 warnings. but in the signals & interfaces tab, i can not find the "signed" i/o in vhd files like: S_encoder1_Z_reg_out : out STD_LOGIC_VECTOR(1 downto 0); S_encoder1_AB_for_interpolation_reg_out : out STD_LOGIC_VECTOR(1 downto 0); S_encoder1_period_counter_reg_out : out signed(31 downto 0); the "signed" signal does not appear in signals & interfaces tab, the std_logic and std_logic_vector signals are ok how can i fix this? should i have to change the signed to std_logic_vector?Link Copied
btw:
i have included the IEEE.NUMERIC_STD in vhd file use IEEE.NUMERIC_STD.ALL;- Mark as New
--- Quote Start --- hi every one; i write my own component in vhd and try to add it in qsys, in the component editor, i and my vhd file and click analyze files, it shows 0 errors and 0 warnings. but in the signals & interfaces tab, i can not find the "signed" i/o in vhd files like: S_encoder1_Z_reg_out : out STD_LOGIC_VECTOR(1 downto 0); S_encoder1_AB_for_interpolation_reg_out : out STD_LOGIC_VECTOR(1 downto 0); S_encoder1_period_counter_reg_out : out signed(31 downto 0); the "signed" signal does not appear in signals & interfaces tab, the std_logic and std_logic_vector signals are ok how can i fix this? should i have to change the signed to std_logic_vector? --- Quote End --- Prefered method to describe external interface for module - std_logic_vector and in implementation you can use casting to or from another type. Hope this problem not due optimisation when CAD rename or even remove unused ports. Perhaps if std_logic_vector works for you then you can use workaround :
entity BlaBlaBla is port ( S_encoder1_period_counter_reg_out : out std_logic_vector (31 downto 0 )); end BlaBlaBla;
architecture v of BlaBlaBla is
signal S_encoder1_period_counter_reg : signed (31 downto 0 );
begin
S_encoder1_period_counter_reg_out <= std_logic_vector(S_encoder1_period_counter_reg);
end v;
Signed/unsigned are perfectly fine for you to use in your HDL design, even at the top level.
But QSYS is pretty rubbish, and only allows std_logic/std_logic_vector ports: Answer: dont use QSYS or just do an internal conversion, as alex suggests above.
