timer in nios ii
hello everyone, i want to ask how much period cycle do the nios ii timer take???? please help mee :cry:
Nios has not a native timer. All processor peripherals are implemented in Qsys.
When you instantiate the Qsys component you can set a fixed period or make it sofware programmable.
If you are working on a Nios system someone else has built for you, refer to the bsp or system.h to retrieve the device capabilities and parameters.
--- Quote Start ---
--- Quote End ---
thank you for your answer. i will check it
