timer problem
I'm new to altera and c-programming. Just can't make the internal timer work.
int main(void)
volatile int * red_leds =(int*) 0x10000000;
volatile int * timer =(int*) 0x10002000;
int data, exit_data, delay, run;
//turning timer on
int counter = 0xee6b280; // 1/(50 mhz) x (0xee6b280) = 5 sec
*(timer + 0x8) = (counter & 0xffff);
*(timer + 0xc) = (counter >> 16) & 0xffff;
*(timer + 0x4) = 0x4;
run=*(timer);
*(red_leds)=0;
while (run==0x00000001) //
*(red_leds)=0x000002aa;
while(1)
*(red_leds)=0;
You defined timer as a pointer to int (=32bit) but then you used it with byte address increments, so you are not writing the correct registers.
Anyway this is a deprecated way of programming.
A few hints:
- use the symbolic defines generated by sopc builder (in system.h file) instead of the numeric addresses 0x10000000, 0x10002000 which would possibly change if you regenerate the system
- don't use pointers but rather the IOWR/IORD macros which automatically match the addressed memory data size
- in this case it would be even better exploiting the timer control macros (IOWR_ALTERA_AVALON_TIMER_CONTROL, IOWR_ALTERA_AVALON_TIMER_PERIODL, ...) available in the HAL driver.
thanks for answer, i've started to use macroses, but timer still isn't working.
# include "system.h"
# include "altera_avalon_timer_regs.h"
# include "altera_avalon_pio_regs.h"
int main(void)
//turning timer on
// 1/(50 MHz) x (0x1DCD6500) = 10 sec
IOWR_ALTERA_AVALON_TIMER_PERIODL (INTERVAL_TIMER_BASE + 0x8, 0x6500);
IOWR_ALTERA_AVALON_TIMER_PERIODH (INTERVAL_TIMER_BASE + 0xC,0x1dcd);
IOWR_ALTERA_AVALON_TIMER_CONTROL (INTERVAL_TIMER_BASE + 0x4, 0x4);
run=IORD_ALTERA_AVALON_TIMER_STATUS(INTERVAL_TIMER_BASE);
run=(run & 0x00000002);
IOWR_ALTERA_AVALON_PIO_DATA(RED_LEDS_BASE, 0);
while (run) //
IOWR_ALTERA_AVALON_PIO_DATA(RED_LEDS_BASE, 0x2AA);
while(1)
* Interval_timer configuration
# define ALT_MODULE_CLASS_Interval_timer altera_avalon_timer
# define INTERVAL_TIMER_ALWAYS_RUN 0
# define INTERVAL_TIMER_BASE 0x10002000
# define INTERVAL_TIMER_COUNTER_SIZE 32
# define INTERVAL_TIMER_FIXED_PERIOD 0
# define INTERVAL_TIMER_FREQ 50000000
# define INTERVAL_TIMER_IRQ 1
# define INTERVAL_TIMER_IRQ_INTERRUPT_CONTROLLER_ID 0
# define INTERVAL_TIMER_LOAD_VALUE 6249999
# define INTERVAL_TIMER_MULT 0.0010
# define INTERVAL_TIMER_NAME "/dev/Interval_timer"
# define INTERVAL_TIMER_PERIOD 125.0
# define INTERVAL_TIMER_PERIOD_UNITS "ms"
# define INTERVAL_TIMER_RESET_OUTPUT 0
# define INTERVAL_TIMER_SNAPSHOT 1
# define INTERVAL_TIMER_SPAN 32
# define INTERVAL_TIMER_TICKS_PER_SEC 8.0
# define INTERVAL_TIMER_TIMEOUT_PULSE_OUTPUT 0
# define INTERVAL_TIMER_TYPE "altera_avalon_timer"
--- Quote Start ---
--- Quote End ---
Timer macros already include the offset.
The correct usage is:
IOWR_ALTERA_AVALON_TIMER_PERIODL (INTERVAL_TIMER_BASE, 0x6500);
IOWR_ALTERA_AVALON_TIMER_PERIODH (INTERVAL_TIMER_BASE, 0x1dcd);
IOWR_ALTERA_AVALON_TIMER_CONTROL (INTERVAL_TIMER_BASE , 0x4);
thanks for help
