12603 Discussions
toolchain-build error using nios2-linux-20100621
hi for all
i've working on my FPGA cyclone 3 board using nios2-linux-20080619 , all work fine
but when i use nios2-linux-20100621 , to built toolchain-buit , ia have some error like
CC libpthread/linuxthreads.old/attr.o CC libpthread/linuxthreads.old/cancel.o In file included from ./include/sys/syscall.h:34, from libpthread/linuxthreads.old/restart.h:16, from libpthread/linuxthreads.old/cancel.c:23: ./include/bits/syscalls.h:10:23: asm/traps.h: No such file or directory make[1]: *** [libpthread/linuxthreads.old/cancel.o] Error 1 make[1]: Leaving directory `/home/zizu/nios2-linux/uClibc' make: *** [/home/zizu/nios2-linux/toolchain-build/../uClibc/lib/libc.a] Error 2
are you sure you are using make 3.81? The later versions of linux distributions use make 3.82 by default.
Check the make version using 'make -v'. If it is indeed 3.82, rename it to something other than 'make', perhaps make3.82 and then install make version 3.81 from the sources. Add the new make binary (v3.81) to your PATH and re-login.
Aijaz
thank's fot your answer , i check my Make version , it's V3.81
i think , the problem is in the uClibc , but i have not the solution ,
if any body have solution , please , i need it soon
ask in Nios Linux mailing list.
how can use Nios Linux mailing list
subscribe and read the rules.
i have update my nios2-linux-20100621 using
cd nios2-linux
cd linux-2.6
git fetch origin
git branch nios2
git checkout -f nios2
git clean -f -x -d
cd ..
cd uClinux-dist
git fetch origin
git branch trunk origin/trunk
git checkout -f trunk
git clean -f -x -d
i have not my first error , but i have a new error like that :
libpthread/linuxthreads.old/wrapsyscall.c:101: error: redefinition of 'msync'
./include/sys/mman.h:97: error: previous definition of 'msync' was here
make: *** [libpthread/linuxthreads.old/wrapsyscall.o] Error 1
Is this problem been resolved? I would like to know how please..
I am experiencing same error. someone says it is a GCC 4.6 problem.. downgrading to gcc 4.1 solves the problem.. I am battling how to downgrade GCC4.6 to 4.1 with no success..
I am using fedora 16 fyi. I wonder what fedora version uses gcc 4.1..
running out of option here..
rgds,
JOSE
i am still trying to figure out a solution for the following error
any solution please. I have no idea about how to proceed from here..
I tried to branch the toolchain with nios2 and trunk as well. but nothing works..
I am using Ubuntu 10.10, gcc 4.1
Afaik I've seen such errors when tried to compile the toolchain using the manual on the internet. It said to compile all the stuff at once, like: make this, make that, make everything_work <- didn't work. Go for separate steps. Firstly make first software, then go to second by hand, etc. Helped for me.
