Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
tried programmer, doesn't work, 64/32 bit problem
I have Quartus 12 running on a 64-bit laptop. For some reason it installed the 32-bit version instead of the 64-bit version. I have a Cyclone II development board turned on in program mode and connected to the USB port, and I brought up the programmer window. I bring up the Hardware Setup window and hit Add Hardware. It says "Attempted to access JTAG server -- internal error code 82 occurred". Auto detect doesn't work. This error appears in the Konsole window I started Quartus from:
--- Quote Start ---
/home/phma/altera/12.0sp2/quartus/bin/jtagd: 69: exit: Illegal number: -1
*** The Quartus II software cannot be started because the current platform,
'linux64', does not appear to be installed in:
'/home/phma/altera/12.0sp2/quartus'.
--- Quote End ---
There is no man page for jtagd or jtag; I don't know what they are. They aren't in the path either.
