I am working on a project on a DE2-115 board that involves both a NIOS processor and the triple speed Ethernet IP core , the problem is that nios ii/e processor works well with the mentioned IP core but when trying to upgrade the processor to nios ii/f it doesn't work and it hangs at the step doing the software reset to the PHY chip. Do anyone have the same issue, or have any suggestion for fixing this issue ? Thanks in advance and highly appreciate your response.Link Copied
Are the Nios II/f and Ethernet IP core running at the same frequency? If they are not in the same frequency, try adding a clock crossing bridge in between them.
Thanks mikedsouze for your reply.
Yes, they are working at the same clock domain (100 MHZ). Even when I applied the provided example by Altera " Using Triple-Speed Ethernet on DE2-115 Boards " it only works with the NIOS ii/e and doesn't work with NIOS ii/f. appreciate your help.Can the system runs "Hello world" ?
Yes I can run the hello world in case if I bypass this step "phy software reset ", cause the program runs infinitely through the while loop of the mentioned step
Hi,Actually i've the same problem but with the DE4. The TSE Tutorial provided by Altera use the NiosII/s classic processor, but when it's upgraded to NiosII/f the same software application stall in PCS reset and MAC reset, so i made the configuration steps described on ug_ethernet.pdf (TSE User Guide) and neither worked. I'm trying to figure out where/what's the problem here too.
Thanks jnasselle for your update , I have done also several trials (putting a clock bridge between NIOS and TSE , clock crossing bridge ) but unfortunately it doesn't work.
anyway thanks again, I will keep trying, and pls let me know if you reach to anything regarding this issue and I will do the same as wellHi,
The solution was to disable the data cache of the NiosII/f :)Hi jnasselle
Thanks alot, You really made my day :) I wanna be your friend ;)Disabling the Data-cache makes the /f compatible with /s.
For compatibility between Nios II/s you will need t o set the following settings in Nios II/f: No Data cache No Tightly Coupled Data master Static branch prediction No MMU/MPU support Internal Interrupt Controller No shadow registerFor more complete information about compiler optimizations, see our Optimization Notice.
