12603 Discussions
trispeed ethernet nios2 eclipse new project and bsp build error
venkatasateesh
Hi Dear intel team,
sub: trispeed ethernet nios2 eclipse new project and bsp build error
i am using quarts prime lite version 20.1 running on windows 10 OS . while  building project to  generating elf file  tri speed ethernet in eclipse ,we are getting some errors as shown below.
wslpath: /mnt/c/nios2_practice/Trispeed_ethernet/ethernet_04_12_21/software/web_server_ENT0_bsp//obj/HAL/src/crt0.o: No such file or directory
touch web_server_ENT0.elf.srec
Info: Building /mnt/c/nios2_practice/Trispeed_ethernet/ethernet_04_12_21/software/web_server_ENT0_bsp/
make --no-print-directory -C /mnt/c/nios2_practice/Trispeed_ethernet/ethernet_04_12_21/software/web_server_ENT0_bsp/
Compiling alt_close.c...
nios2-elf-gcc.exe -xc -MP -MMD -c -I./drivers/inc -I./drivers/inc/iniche -I./iniche/inc -I./iniche/src/h -I./iniche/src/h/nios2 -I./iniche/src/nios2 -I./UCOSII/inc -I./HAL/inc -I. -I./drivers/inc -pipe -D__hal__ -DALT_NO_INSTRUCTION_EMULATION -DALTERA_TRIPLE_SPEED_MAC -DALT_INICHE -DRO_ZIPFS -D__ucosii__ -DALTERA_AUTONEG_TIMEOUT_THRESHOLD=2500 -DALTERA_CHECKLINK_TIMEOUT_THRESHOLD=10000 -DALTERA_NOMDIO_TIMEOUT_THRESHOLD=1000000 -DTSE_MY_SYSTEM -O0 -g -Wall -mno-hw-div -mhw-mul -mno-hw-mulx -mgpopt=global -o obj/HAL/src/alt_close.o HAL/src/alt_close.c
In file included from ./HAL/inc/includes.h:23,
from ./UCOSII/inc/priv/alt_sem_ucosii.h:45,
from ./UCOSII/inc/os/alt_sem.h:75,
from ./HAL/inc/priv/alt_file.h:44,
from HAL/src/alt_close.c:37:
./UCOSII/inc/ucos_ii.h:1708:2: error: #error "OS_CFG.H, Missing OS_TICKS_PER_SEC: Sets the number of ticks in one second"
1708 | #error "OS_CFG.H, Missing OS_TICKS_PER_SEC: Sets the number of ticks in one second"
make[1]: *** [Makefile:746: obj/HAL/src/alt_close.o] Error 1
make: *** [Makefile:846: /mnt/c/nios2_practice/Trispeed_ethernet/ethernet_04_12_21/software/web_server_ENT0_bsp/-recurs-make-lib] Error 2
10:49:35 Build Finished (took 9s.144ms)
                                          i am requesting anyone know  solution  for this .let me known  steps to resolve the above issue .i am attaching some of error image also
     i am looking forward for your response
Thanks &Regards
sateesh
EricMunYew_C_Intel
venkatasateesh
Hi Dear intel team,
i have tried already this solution https://www.intel.com/content/www/us/en/support/programmable/articles/000073953.html,but the error did not resolved .could you Suggest any other solution for the above issue .
Thanks&Regards
B.sateesh
venkatasateesh
Hi Dear Intel team,
the issue did not resolve ,i am looking for technical  assistance for above  issue ,do you have instant chatting  technical team to get support with out delay .
                                                I am looking forward for your response
Thanks&Regards
B.Sateesh
EricMunYew_C_Intel
It should be fixed in Quartus Lite 20.1.1. Have you tried it.
venkatasateesh
Hi intel technical team ,
      i have tried already , what ever suggestion  given above ,could you give any other solution for  above issue.in every IDE  versions several bugs coming .still your releasing  upgraded version without fixing issues.
Thanks&Regards
B.Venkata Sateesh
EricMunYew_C_Intel
You may refer to below and try to uninstall and reinstall the WSL.
https://www.intel.com/content/www/us/en/support/programmable/articles/000074066.html
venkatasateesh
Hi intel team,
  i have  resolved the issue. very much early before coming your post.you can close issue
EricMunYew_C_Intel
Since this thread had been answered, we shall close this thread. If you still need further assistance, you are welcome to post a response within 15days or open a new thread, some one will be right with you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
