u-boot for NIOS2
Dear Members,
The folder at:
ftp.altera.com/outgoing/nios2-linux/20120802
contains 2 toolchains:
1. nios2-linux-toolchain-mmu-20120802.tgz
2. nios2-linux-gcc3-20120802.tgz
*** Which one should I use to build u-boot in this folder ?
The wiki page supports the following boards:
1. 3C120
2. 4S230GX
3. BeMicroSDK
4. DE1_SD_Card_Audio
the first step in u-boot build is:
make ????_config
*** Should I run: "make nios2_generic" ?
*** Should I set any addresses of MAC, Flash in u-boot tree ?
*** Can I use ALTERA's USB blaster to burn u-boot.bin ?
Zvika
