Dear Members,
The folder at: ftp.altera.com/outgoing/nios2-linux/20120802 contains 2 toolchains: 1. nios2-linux-toolchain-mmu-20120802.tgz 2. nios2-linux-gcc3-20120802.tgz *** Which one should I use to build u-boot in this folder ? The wiki page supports the following boards: 1. 3C120 2. 4S230GX 3. BeMicroSDK 4. DE1_SD_Card_Audio the first step in u-boot build is: make ????_config *** Should I run: "make nios2_generic" ? *** Should I set any addresses of MAC, Flash in u-boot tree ? *** Can I use ALTERA's USB blaster to burn u-boot.bin ? Thanks, ZvikaLink Copied
