u-boot for .h file
Hi ,
I need to port the U-boot (2011.6) to NIOS-II Cyclone-III based customized board. Started following the Altera wiki http://www.alterawii.com/wiki/dasuboot instructions.
I cannot generat the my_nios2_fpga.h from sopc file
(My environment is UBUNTU 10.4)
Because when I key in "yum install perl-XML-LibXML".
The information shows
Setting up Install Process
No package perl-XML-LibXML available.
Nothing to do
Hence, I cannot success when I execute "sopc-create-config-files my_nios2_sopc.sopc my_nios2_fpga.h"
The error information shows
sopc-create-config-files:1: parser error : Start tag expected, '<' not found
# !/usr/bin/perl
Could you tell me how can I do
Thank you very much.
I am also having a problem with the sopc-create-config-files script.
I am running CentOS 5.6 and I was correctly able to install the
But when I run the sopc-create-config-files script I get
a message that says "CPU not found" and no *.h file is created.
The code inside the script is looking for nodes like
"/system/module" but the parsed document has nodes like "/EnsembleReport/module".
Is there a problem with the sopc-create-config-files script?
