uCLinux or Linux for Max10K
Hello all,
how can I configurate and build the Linux for MAX10K family ? I use the kit BeMicro Max10, but it is not important.
I would able to build uClinux for Cyclone III, Cyclone IV, when i use ptf file for menuconfig in 4-6 years old uclinux, but now ... i have sopcinfo and qsys, it is all.
Thank you for answer.
H. Naceradsky, Czech Republic
--- Quote Start ---
--- Quote End ---
Please refer to the documents in
https://rocketboards.org/foswiki/view/documentation/niosiilinuxusermanual
. And also be aware that everything is not done automatically.
Kazu
Thank you for your answer. It does not seem easy, but i try it.
Other way, is anywhere some java program for convert sopcinfo to ptf ?:) (i dont need the last version of linux)
Honza
i was succesful only in few points, i downloaded from git reporitory sopc2dts and make sopc2dts.jar, which can convert sopcinfo to dts. I create directory /home/rocket_linux and create and downloaded /buildroot, /linux-socfpga and sourcery binary codebench lite 2014.05-17 and when i try to install, it finished with permission denied ... in picture. How continue ?
I try in make nios2_defconfig in buildroot directory, make 3c120_defconfig in directory linux-socfpga and everything finished with error. Is somewhere described more details, how to setting the linux machine ? (i use linux, which i used for building uclinux for nios2 2-4 year ago...
Honza
--- Quote Start ---
Honza
--- Quote End ---
Sorry, your JPEG veiw is too small and indistinct, so I can't read the error message.
Kazu
it is strange, i included png about 99kB.
So i wrote:
$ /bin/sh sourgeryg++-2014.05-47-nios2-linux-gnu.bin
Extracting installer ...
Starting installer ...
/tmp/sourgeryg++-2014.05-47-nios2-linux-gnu.bin_sfx.8a451e21/installer/jre/bin.
./lib/i386/client/libjvm.so: cannot restore segment prot after reloc: Permission denied.
It was all ... how solve this error ? (i am not linux specialist)
Thank you.
Honza
--- Quote Start ---
--- Quote End ---
Are you using SELinux? If so, please refer to the next pages
http://www.cubrid.org/wiki_tutorials/entry/cannot-restore-segment-prot-after-reloc-permission-denied
http://stackoverflow.com/questions/19223963/selinux-cannot-restore-segment-prot-after-reloc-permission-denied
... and so on.
P.S. I'm also not a Linux specialist and I sometimes refer to web sites for Linux commands, for example
http://bijo-linux.com/
(Sorry, Japanese only). (-:
Kazu
Your JPEG veiw is too small and indistinct. Please, reupload it. Thank you
