I just downloaded the uClinux installer version 1.2 that claims to support the 1.01 release of NIOSII <div class='quotetop'>QUOTE </div> --- Quote Start --- The v1.2 release is designed to work with Quartus® II 4.0 sp1 on: Windows NT, Windows 2000 and Windows XP. The v1.2 release is designed to work with the v1.01 release of the Altera Nios II Development Kit.[/b] --- Quote End --- When I start the installation I get the error "Could not find Altera NiosII Development Kit 1.0 or 1.01 on this system. Please install and run this setup again." What can I do about it?Link Copied
We're looking into it today and we'll get back to you about it.
when i setup Stand-Alone LWIP,the same occued !
I am currently looking into this problem. I assume you guys have the Nios 1.01 installed on your systems?
I have installed NIOS II 1.0 and SP1.
When I start the NIOS II SDK shell I see: <div class='quotetop'>QUOTE </div> --- Quote Start --- ... Welcome to the Nios II Development Kit Version 1.01, Built Thu Sep 2 00:09:35 PDT 2004 ...[/b] --- Quote End --- What information do you need to locate the problem?- Mark as New
The installer is looking for specific registry entries that are set when the Nios 1.01 is installed.
It would be helpful if you could email me a couple of registry dumps of the following registry keys:HKEY_LOCAL_MACHINE\SOFTWARE\Altera Corporation
HKEY_LOCAL_MACHINE\SOFTWARE\Cygnus Solutions
To do this, select "Run..." from the start menu and run "regedit". Once in the registry editor, navigate to the paths shown above, right click and export each one to a .reg file. Email the .reg files to randy@microtronix.com.
