uClinux Boot problem
I am testing my own custom board with EP1C12Q240, Flash=16bit*4M, Sdram=32bit*2M.
My system has NiosII/f Core, uart, jtag-uart, sdram, flash, epcs_controller, timer and some PIOs.
I use U-Boot to boot uClinux of Microtronix 1.4.
When I run bootm command to boot uClinux, there display
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
==> bootm 0x50000
# # Booting image at 00050000 ...
   Image Name:   Linux Kernel Image
   Image Type:   Nios-II Linux Kernel Image (gzip compressed)
   Data Size:    458311 Bytes = 447.6 kB
   Load Address: 00800000
   Entry Point:  00800000
   Verifying Checksum ... OK
   Uncompressing Kernel Image ... OK
Linux version 2.6.11-uc0 (LiangYi@ciitec-liangyi) (gcc version 3.4.1 (Altera Nios II 5.0 b73))# 1 Thu Feb 23 15:45:58 2006
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
Built 1 zonelists
Kernel command line: root=/dev/mtdblock0 ro
PID hash table entries: 64 (order: 6, 1024 bytes)
Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory available: 7016k/8192k RAM, 0k/0k ROM (850k kernel code, 206k data)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Linux NoNET1.0 for Linux 2.6
NIOS serial driver version 0.0
ttyS0 (irq = 3) is a builtin NIOS UART
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
Microtronix map: Found 1 x16 devices at 0x0 in 16-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
Microtronix map: CFI does not contain boot bank location. Assuming top.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
cmdlinepart partition parsing not available
RedBoot partition parsing not available
Using Microtronix development partition definition
Creating 2 MTD partitions on "Microtronix map":
0x00200000-0x00800000 : "romfs"
0x00000000-0x00200000 : "loader/kernel"
VFS: Mounted root (romfs filesystem) readonly.
Freeing unused kernel memory: 52k freed (0x8f0000 - 0x8fc000)
expand: from=/ramfs.img to=/dev/ram0
expand: from=/ramfs.img to=/dev/ram1
SIOCSIFADDR=-1: 9
SIOCGIFFLAGS = -1: Bad file descriptor (9)
SIOCADDRT=-1: 9
Unable to create socket
close on exec: : Bad file descriptor
setsockopt: : Function not implemented
Unable to bind server socket: : Function not implemented
Unable to listen to socket
Unable to listen to socket[/b]
--- Quote End ---
I do not know What is wrong?
I use NiosII-IDE to generate vmlinux.bin and romfs.bin and do
--- Quote Start ---
$ gzip -9 vmlinux.bin
$ mkimage -A nios2 -O linux -T kernel -C gzip -a 0x00800000 -e 0x00800000 -n &#39;Linux Kernel Image&#39; -d vmlinux.bin.gz uImage.img
$ bin2flash –flash=U5 –location=0x00050000 –input=uImage.img –output=uImage.flash
$ nios2-flash-programmer –base=0x00800000 –input=uImage.flash –sof=<path to pgm sof>
$ bin2flash --flash=U5 --location=0x00200000 --input=romfs.bin --output=romfs.flash
$ nios2-flash-programmer –base=0x00800000 –input=romfs.flash –sof=<path to pgm sof>[/b]
--- Quote End ---
Then, run bootm and display above. Can someone help me?
BTW, another question. When I use
--- Quote Start ---
$ mkimage -A nios2 -O linux -T filesystem -C none -a 0x00a00000 -e 0x00a00000 -n &#39;romfs&#39; -d romfs.bin romfs.img
$ bin2flash --flash=U5 --location=0x00200000 --input=romfs.img --output=romfs.flash
--- Quote End ---
There display
--- Quote Start ---
uClinux/Nios II
Built 1 zonelists
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,0)[/b]
--- Quote End ---
I do not know what different between these two method and which is correct for me and how to deal with the problem.
Thank you,
LiangYi
Hi LiangYi,
The first error you&#39;re getting
SIOCSIFADDR=-1: 9 SIOCGIFFLAGS = -1: Bad file descriptor (9) SIOCADDRT=-1: 9 Unable to create socket close on exec: : Bad file descriptor setsockopt: : Function not implemented Unable to bind server socket: : Function not implemented Unable to listen to socket Unable to create socket close on exec: : Bad file descriptor setsockopt: : Function not implemented Unable to bind server socket: : Function not implemented Unable to listen to socket Unable to create socket close on exec: : Bad file descriptor setsockopt: : Function not implemented Unable to bind server socket: : Function not implemented Unable to listen to socket
Is (probably) due to the fact that you haven&#39;t compiled in an ethernet driver (And from what I read you don&#39;t have one so that&#39;s perfectly OK) but the standard rc file in the ramfs.img tries to configure ethernet (SIOCSIFADDR=-1: 9 SIOCGIFFLAGS = -1: Bad file descriptor (9) SIOCADDRT=-1: 9) and then tries to start the inet deamon and maybe dhcpc (Don&#39;t know exactly, I don&#39;t use the standard rc file anymore). That&#39;s what the socket errors are from.
I expect your system boots fine even though it&#39;s complaining. Make sure to enable your lo device (loopback network).
When you "fix" the rc file (/etc/rc) you&#39;re system should run fine &#153;.
Regarding the second error: no idea....
Hope you get it running!
Walter Goossens
Hi LiangYi,
--- Quote Start ---
BTW, another question. When I use <div class='quotetop'>QUOTE
--- Quote End ---
--- Quote Start ---
$ mkimage -a nios2 -o linux -t filesystem -c none -a 0x00a00000 -e 0x00a00000 -n &#39;romfs&#39; -d romfs.bin romfs.img
--- Quote End ---
[/b]
--- Quote End ---
Don&#39;t use mkimage -- it adds an &#39;image&#39; header to your romfs image ... which the
kernel knows nothing about. Just use bin2flash and the flash programmer as you
normally would. In most cases, mkimage is used only for the kernel itself ... since
u-boot for Nios does not support separate kernel/ramdisk image files at this time.
--Scott
Hi Walter,
Thank you for your reply.
I have no ethernet device, but do I need networking support?
Otherwise, How can I "fix" the rc file of Microtronix Linux 1.4?
I have re-configured the kernel with networking support but have not select any ethernet device. When I boot kernel, the Unable to listen to socket error disappear, but stop here
--- Quote Start ---
uClinux/Nios II
Built 1 zonelists
Memory available: 6368k/8192k RAM, 0k/0k ROM (1407k kernel code, 297k data)
NET: Registered protocol family 16
NET: Registered protocol family 2
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP established hash table entries: 512 (order: 0, 4096 bytes)
TCP bind hash table entries: 512 (order: -1, 2048 bytes)
TCP: Hash tables configured (established 512 bind 512)
NET: Registered protocol family 17
Freeing unused kernel memory: 60k freed (0x98a000 - 0x998000)
expand: from=/ramfs.img to=/dev/ram1[/b]
--- Quote End ---
Here cursor holdup and can not run anymore.
Why?
Thank you,
LiangYi
Hi LiangYi,
It seems to have problems in MTD.
It should be easier if you follow my buildroot guide,
http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174
It does not need romfs, ramdrive, cfi, or mtd to boot.
tschmelcher had a post about u-boot to be used with it,
http://forum.niosforum.com/forum/index.php?showtopic=3253 (http://forum.niosforum.com/forum/index.php?showtopic=3253)
Hi All,
Does nobody help me?
I read the start-up text and find that
--- Quote Start ---
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize[/b]
--- Quote End ---
Here, I do not know why use RAMDISK driver, I also can not find it during Kernel config.
Then, display
--- Quote Start ---
Freeing unused kernel memory: 64k freed (0x99c000 - 0x9ab000)
--- Quote End ---
Here, I know romfs has been mounted. But, ramfs.img can not be expanded. So, the boot process can not continue anymore. I do not know why here can not be expanded.
Can help me?
Thank you,
LiangYi
Hi LiangYi,
I&#39;ll try once more ...
--- Quote Start ---
--- Quote End ---
From your earlier post:
--- Quote Start ---
$ mkimage -A nios2 -O linux -T filesystem -C none -a 0x00a00000 -e 0x00a00000 -n &#39;romfs&#39; -d romfs.bin romfs.img[/b]
--- Quote End ---
Are you using mkimage to create your ramfs.img file?
--Scott
As was suggested by wgoossens, the problem should be in the etc/rc after mounting all fs.
Try findfile for the etc/rc.
Try comment out all that after mounts, eg ifattach, inetd, boa...
Hi Scott,
--- Quote Start ---
Are you using mkimage to create your ramfs.img file?[/b]
--- Quote End ---
I have tried this before, but display <div class='quotetop'>QUOTE </div>
--- Quote Start ---
Kernel Panic:......[/b]
--- Quote End ---
. So, I now do not use mkimage and directly program the romfs.flash(has been transfered from romfs.bin). Then display above I described.
Hi hippo,
I can not find etc/rc anywhere. Can you tell me where it is in Microtronix Linux directory?
Thany you,
LiangYi
LiangYi,
Sorry, I don&#39;t use IDE/cygwin. A lot of people have trouble with it, too.
Repeat again, add a PC to run Linux. It would save you a lot of time/life.
Hi hippo,
Thank you. But now, I want to implement booting uClinux under IDE, then I will try to do it under Linux. I will ask you question later.
I retry booting without U-Boot, just follow Microtronix&#39;s Quick Guide, it is OK.
--- Quote Start ---
Linux version 2.6.11-uc0 (LiangYi@ciitec-liangyi) (gcc version 3.4.1 (Altera Nios II 5.0 b73))# 4 Tue Mar 7 16:04:58 2006
uClinux/Nios II
Built 1 zonelists
Memory available: 6552k/8192k RAM, 0k/0k ROM (1259k kernel code, 263k data)
Serial: JTAG UART driver $Revision: 1.4 $
ttyJ0 at MMIO 0x82000800 (irq = 1) is a jtag_uart
Freeing unused kernel memory: 60k freed (0x960000 - 0x96e000)
/etc/issue                         www.microtronix.com           June 2005
                             welcom to Linux on the Nios II
Nios2 login:[/b]
--- Quote End ---
Next, I try with U-Boot. I follow the step
Build U-Boot and download to flash 0x0
Use vmlinux.bin -> mkimage(not gzip) -> bin2flash(location=0x50000) -> download
Use romfs.bin -> bin2flash(location=0x200000) -> download
Run
--- Quote Start ---
==> bootm 0x50000
   Image Type:   Nios-II Linux Kernel Image (uncompressed)
   Data Size:    1504864 Bytes =  1.4 MB
OK
uClinux/Nios II
Built 1 zonelists
Cursor wink here, but nothing displays. Then, I type anything from keypad and all can be displayed in the terminal where cursor wink. Why?[/b]
--- Quote End ---
So, I want to ask if U-Boot has some settings involved in Kernel of Filesystem Booting and make this happen.
Thank you,
LiangYi
Why do you want to use u-boot with IDE?
