12603 Discussions
uClinux Dist make won't go through
After doing twice make, tried NON_SMP_BUILD=1 make
still won't go through, looks like being lack of romfs, repeated make romfs, won't help.
Please suggest,
ethan@linux:~/uClinux-dist> NON_SMP_BUILD=1 make
make -C tools/ucfront
make[1]: Entering directory `/home/ethan/uClinux-dist/tools/ucfront'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/home/ethan/uClinux-dist/tools/ucfront'
ln -sf /home/ethan/uClinux-dist/tools/ucfront/ucfront tools/ucfront-gcc
ln -sf /home/ethan/uClinux-dist/tools/ucfront/ucfront tools/ucfront-g++
ln -sf /home/ethan/uClinux-dist/tools/ucfront/ucfront-ld tools/ucfront-ld
make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- -j1 -C linux-2.6.x zImage || exit 1
no emulation specific options.
make[1]: Entering directory `/home/ethan/uClinux-dist/linux-2.6.x'
CHK include/nios2_system.h
perl -I/home/ethan/uClinux-dist/linux-2.6.x/arch/nios2nommu/scripts /home/ethan/ uClinux-dist/linux-2.6.x/arch/nios2nommu/scripts/gen_nios2_system.h.pl cpu sdram ext_flash < /home/ethan/ethan/niosII_stratix_1s40/standard/std_1s40.ptf > inclu de/nios2_system.h.tmp; if [ -r include/nios2_system.h ] && cmp -s include/nios2_ system.h include/nios2_system.h.tmp; then rm -f include/nios2_system.h.tmp; else echo &#39; UPD include/nios2_system.h&#39;; mv -f include/nios2_system.h.tmp inclu de/nios2_system.h; fi
CHK include/linux/version.h
CHK include/linux/utsrelease.h
CHK include/linux/compile.h
/home/ethan/uClinux-dist/linux-2.6.x/scripts/gen_initramfs_list.sh: Cannot ope n &#39;../romfs ../vendors/Altera/nios2nommu/romfs_list&#39;
make[2]: *** [usr/initramfs_data.cpio.gz] Error 1
make[1]: *** [usr] Error 2
make[1]: Leaving directory `/home/ethan/uClinux-dist/linux-2.6.x&#39;
make: *** [linux] Error 1
ethan@linux:~/uClinux-dist> make
make[1]: Entering directory `/home/ethan/uClinux-dist/tools/ucfront&#39;
make[1]: Nothing to be done for `all&#39;.
make[1]: Leaving directory `/home/ethan/uClinux-dist/tools/ucfront&#39;
make[1]: Entering directory `/home/ethan/uClinux-dist/linux-2.6.x&#39;
perl -I/home/ethan/uClinux-dist/linux-2.6.x/arch/nios2nommu/scripts /home/ethan/uClinux-dist/linux-2.6.x/arch/nios2nommu/scripts/gen_nios2_system.h.pl cpu sdram ext_flash < /home/ethan/ethan/niosII_stratix_1s40/standard/std_1s40.ptf > include/nios2_system.h.tmp; if [ -r include/nios2_system.h ] && cmp -s include/nios2_system.h include/nios2_system.h.tmp; then rm -f include/nios2_system.h.tmp; else echo &#39; UPD include/nios2_system.h&#39;; mv -f include/nios2_system.h.tmp include/nios2_system.h; fi
/home/ethan/uClinux-dist/linux-2.6.x/scripts/gen_initramfs_list.sh: Cannot open &#39;../romfs ../vendors/Altera/nios2nommu/romfs_list&#39;
Did you apply the nios2 patches as in the wiki?
the file linux-2.6.x/usr/Makefile need the patch, or you can look at linux-2.6.19 or linux-2.6.20 .
TO_BE_DONE
Applied patch uClinux-dist-20070130-nios2-02.diff.gz everything works find, thank you for your time.
Just curious: would all the updates in lower version of patch all included in high version?
like uClinux-dist-20070130-nios2-02.diff.gz > uClinux-dist-20060803-nios2-02.diff.gz
Cause I need both Ethernet & USB.
Maybe can help newbies by explaining the differece usage of all those patchs.
I didn&#39;t see Changelog of uClinux-dist-20070130-nios2-02.diff.gz
These nios2 patches has been submitted to uClinux-dist, and merged. So the last patch was smaller, and just some minor update after the release. Don&#39;t use older patches on newer dist release, or it will be over patched.
Well, things have changed now ... nios wiki not working , .. missing links .. :(
Als0 there is not further patch for nios after 2007,
Can any 1 tell what is the latest way to download uclinux on ltera DE2 board
NIOS Wiki moved to the Altera site:
http://www.alterawiki.com/wiki/linux_for_the_nios_ii_processor
(and is not that easy to be found and searched any more:cry:)
-Michael
Thanks Micheal :)
