http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif
Hi, while building kernel standard_1c12 project the below error occurred: Error: expected comma after "nobreak"[/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/arch/nios2nommu/kernel/entry.S] what means? Reply please!Link Copied
Hi giok,
Are you using Nios-II v1.1? --Scott- Mark as New
Greetings,
I had the same problem, thankfully, so had someone else. I can't find out how to link to a thread so here's a copy, and he quotes ... user: cetic Posted: Jan 18 2005, 11:41 AM Nb : I fixed the problem by replacing "nobreak" by "nobreak,0", and the corresponding "break" by "break,0", it seems to be ok..... Regards, cetic ... Thank you Mr Celtic. Sam- Mark as New
Thank,
I fix the problem in the same way!!!!!! Giok
