uClinux TSE not working
i have a problem with my Ethernet on the DE2-115 Board using uClinux.
When i set up "eth0":
root:/> ifconfig eth0 192.168.14.92 up root:/> ifconfig eth0 eth0 Link encap:Ethernet HWaddr 00:11:22:33:44:55 inet addr:192.168.14.92 Bcast:192.168.14.255 Mask:255.255.255.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:7 errors:7 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 Base address:0x2400
There are 7 errors on RX-Line.
When i do "ping":
root:/> ping 192.168.14.14 PING 192.168.14.14 (192.168.14.14): 56 data bytes ^C --- 192.168.14.14 ping statistics --- 3 packets transmitted, 0 packets received, 100% packet loss root:/> ifconfig eth0 eth0 Link encap:Ethernet HWaddr 00:11:22:33:44:55 inet addr:192.168.14.92 Bcast:192.168.14.255 Mask:255.255.255.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:43 errors:43 dropped:0 overruns:0 frame:0 TX packets:3 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 Base address:0x2400
the Errors increase.
Output of ethtool:
root:/> ethtool eth0 Settings for eth0: Supported ports: Supported link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Half 1000baseT/Full Supports auto-negotiation: Yes Advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Half 1000baseT/Full Advertised auto-negotiation: Yes Speed: 1000Mb/s Duplex: Full Port: MII PHYAD: 17 Transceiver: external Auto-negotiation: on Current message level: 0x00000000 (0) Link detected: yes
root:/> ethtool -S eth0 NIC statistics: aFramesTransmittedOK: 3 aFramesReceivedOK: 0 aFramesCheckSequenceErrors: 3 aAlignmentErrors: 1 aOctetsTransmittedOK: 138 aOctetsReceivedOK: 0 aTxPAUSEMACCtrlFrames: 0 aRxPAUSEMACCtrlFrames: 0 ifInErrors: 47 ifOutErrors: 0 ifInUcastPkts: 0 ifInMulticastPkts: 0 ifInBroadcastPkts: 0 ifOutDiscards: 0 ifOutUcastPkts: 0 ifOutMulticastPkts: 0 ifOutBroadcastPkts: 3 etherStatsDropEvent: 0 etherStatsOctets: 120993 etherStatsPkts: 47 etherStatsUndersizePkts: 0 etherStatsOversizePkts: 0 etherStatsPkts64Octets: 0 etherStatsPkts65to127Octets: 40 etherStatsPkts128to255Octets: 3 etherStatsPkts256to511Octets: 0 etherStatsPkts512to1023Octets: 0 etherStatsPkts1024to1518Octets: 1 etherStatsPkts1519toXOctets: 0 etherStatsJabbers: 0 etherStatsFragments: 3 ipaccTxConf: 0 ipaccRxConf: 0 ipaccRxStat: 0 ipaccRxStatSum: 0
What could be the Problem?
With best regards,
Jan
--- Quote Start ---
When i do "ping":
Output of ethtool:
--- Quote End ---
Did you use a PLL to adjust the phase of Rx clock?
Kazu
TO_BE_DONE
root:/> Oops: Exception in kernel mode, sig: 4 r1: 00000004 r2: cfc1e008 r3: 00000004 r4: 00000000 r5: cfc1ffa4 r6: 00000001 r7: 00000001 r8: 00000000 r9: c8734894 r10: 00000004 r11: 00000004 r12: 01000000 r13: 00000400 r14: 00000000 r15: d9274300 ra: c8000bbc fp: 00000000 sp: cfc1fe3c gp: 0000ca80 ea: c8002440 estatus: 00000001 Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000004
Maybe sig:4 means that the CPU encounters an illegal instruction, so please get its objdump file like
nios2-***-linux-gnu-objdump -d -S vmlinux > vmlinux.objdump
and check whether the instruction located at 0xc8002440 is illegal or not. If the instruction is legal, I recommend you once to check the timing of SDRAM I/Os etc.
Kazu
Thank you Kazu for helping me! :)
The problem, why my TSE was not working, relays to wrong constrains.
My design now is as followed:
module uClinux( // Clock input CLOCK_50, // KEY input KEY, // Ethernet 1 output ENET1_GTX_CLK, output ENET1_MDC, inout ENET1_MDIO, output ENET1_RESET_N, input ENET1_RX_CLK, input ENET1_RX_DATA, input ENET1_RX_DV, output ENET1_TX_DATA, output ENET1_TX_EN, // SDRAM output DRAM_CLK, output DRAM_ADDR, output DRAM_BA, output DRAM_CAS_N, output DRAM_CKE, output DRAM_CS_N, inout DRAM_DQ, output DRAM_DQM, output DRAM_RAS_N, output DRAM_WE_N, // RS232 input UART_RXD, output UART_TXD ); wire sys_clk; wire enet_tx_clk_125, enet_tx_clk_25, enet_tx_clk_2p5, tx_clk; wire enet_gtx_clk_125, enet_gtx_clk_25, enet_gtx_clk_2p5; wire core_reset_n; wire mdc, mdio_in, mdio_oen, mdio_out; wire eth_mode, ena_10; assign mdio_in = ENET1_MDIO; assign ENET1_MDC = mdc; assign ENET1_MDIO = mdio_oen ? 1'bz : mdio_out; assign ENET1_RESET_N = core_reset_n; assign DRAM_CLK = sys_clk; assign ENET1_GTX_CLK = eth_mode ? enet_gtx_clk_125 : // GbE Mode = 125MHz clock ena_10 ? enet_gtx_clk_2p5 : // 10Mb Mode = 2.5MHz clock enet_gtx_clk_25; // 100Mb Mode = 25 MHz clock pll pll_inst( .areset (~KEY), .inclk0 (CLOCK_50), .c0 (sys_clk), .c1 (enet_tx_clk_125), .c2 (enet_tx_clk_25), .c3 (enet_tx_clk_2p5), .locked (core_reset_n) ); enet_pll_90 gtx_pll_inst( .areset (~KEY), .inclk0 (CLOCK_50), .c0 (enet_gtx_clk_125), .c1 (enet_gtx_clk_25), .c2 (enet_gtx_clk_2p5), .locked () ); assign tx_clk = eth_mode ? enet_tx_clk_125 : // GbE Mode = 125MHz clock ena_10 ? enet_tx_clk_2p5 : // 10Mb Mode = 2.5MHz clock enet_tx_clk_25; // 100Mb Mode = 25 MHz clock nios_system system_inst ( .reset_reset_n (core_reset_n), .clk_clk (sys_clk), .sdram_wire_addr (DRAM_ADDR), .sdram_wire_ba (DRAM_BA), .sdram_wire_cas_n (DRAM_CAS_N), .sdram_wire_cke (DRAM_CKE), .sdram_wire_cs_n (DRAM_CS_N), .sdram_wire_dq (DRAM_DQ), .sdram_wire_dqm (DRAM_DQM), .sdram_wire_ras_n (DRAM_RAS_N), .sdram_wire_we_n (DRAM_WE_N), .rs232_external_connection_rxd (UART_RXD), .rs232_external_connection_txd (UART_TXD), .tse_mac_conduit_connection_tx_clk (tx_clk), .tse_mac_conduit_connection_rx_clk (ENET1_RX_CLK), .tse_mac_conduit_connection_mdc (mdc), .tse_mac_conduit_connection_mdio_in (mdio_in), .tse_mac_conduit_connection_mdio_out (mdio_out), .tse_mac_conduit_connection_mdio_oen (mdio_oen), .tse_mac_conduit_connection_rgmii_in (ENET1_RX_DATA), .tse_mac_conduit_connection_rgmii_out (ENET1_TX_DATA), .tse_mac_conduit_connection_rx_control (ENET1_RX_DV), .tse_mac_conduit_connection_tx_control (ENET1_TX_EN), .tse_mac_conduit_connection_eth_mode (eth_mode), .tse_mac_conduit_connection_ena_10 (ena_10) ); endmodule
And my .sdc:
create_clock -period 20 create_clock -name {enet_rx_clk_125} -period 8 create_clock -name {enet_rx_clk_25} -period 40 -add create_clock -name {enet_rx_clk_2_5} -period 400 -add create_clock -name {enet_rx_clk_125_virt} -period 8 -waveform { 2.000 6.000 } create_clock -name {enet_rx_clk_25_virt} -period 40 -waveform { 10.000 30.000 } create_clock -name {enet_rx_clk_2_5_virt} -period 400 -waveform { 100.000 300.000 } # Create Generated Clock create_generated_clock -source {pll_inst|altpll_component|auto_generated|pll1|inclk} -multiply_by 2 -duty_cycle 50.00 -name {sys_clk} {pll_inst|altpll_component|auto_generated|pll1|clk} create_generated_clock -source {pll_inst|altpll_component|auto_generated|pll1|inclk} -divide_by 2 -multiply_by 5 -duty_cycle 50.00 -name {enet_tx_clk_125} {pll_inst|altpll_component|auto_generated|pll1|clk} create_generated_clock -source {pll_inst|altpll_component|auto_generated|pll1|inclk} -divide_by 2 -multiply_by 1 -duty_cycle 50.00 -name {enet_tx_clk_25} {pll_inst|altpll_component|auto_generated|pll1|clk} create_generated_clock -source {pll_inst|altpll_component|auto_generated|pll1|inclk} -divide_by 20 -multiply_by 1 -duty_cycle 50.00 -name {enet_tx_clk_2p5} {pll_inst|altpll_component|auto_generated|pll1|clk} create_generated_clock -source {gtx_pll_inst|altpll_component|auto_generated|pll1|inclk} -divide_by 2 -multiply_by 5 -duty_cycle 50.00 -phase 90 -name {enet_gtx_clk_125} {gtx_pll_inst|altpll_component|auto_generated|pll1|clk} create_generated_clock -source {gtx_pll_inst|altpll_component|auto_generated|pll1|inclk} -divide_by 2 -multiply_by 1 -duty_cycle 50.00 -phase 90 -name {enet_gtx_clk_25} {gtx_pll_inst|altpll_component|auto_generated|pll1|clk} create_generated_clock -source {gtx_pll_inst|altpll_component|auto_generated|pll1|inclk} -divide_by 20 -multiply_by 1 -duty_cycle 50.00 -phase 90 -name {enet_gtx_clk_2p5} {gtx_pll_inst|altpll_component|auto_generated|pll1|clk} # Set Input Delay set_input_delay -clock enet_rx_clk_125_virt -max 2.5 ENET1_RX_DV}] -add_delay set_input_delay -clock enet_rx_clk_125_virt -max 2.5 ENET1_RX_DV}] -clock_fall -add_delay set_input_delay -clock enet_rx_clk_125_virt -min 1.5 ENET1_RX_DV}] -add_delay set_input_delay -clock enet_rx_clk_125_virt -min 1.5 ENET1_RX_DV}] -clock_fall -add_delay set_input_delay -clock enet_rx_clk_25_virt -max 2.5 ENET1_RX_DV}] -add_delay set_input_delay -clock enet_rx_clk_25_virt -max 2.5 ENET1_RX_DV}] -clock_fall -add_delay set_input_delay -clock enet_rx_clk_25_virt -min 1.5 ENET1_RX_DV}] -add_delay set_input_delay -clock enet_rx_clk_25_virt -min 1.5 ENET1_RX_DV}] -clock_fall -add_delay set_input_delay -clock enet_rx_clk_2_5_virt -max 2.5 ENET1_RX_DV}] -add_delay set_input_delay -clock enet_rx_clk_2_5_virt -max 2.5 ENET1_RX_DV}] -clock_fall -add_delay set_input_delay -clock enet_rx_clk_2_5_virt -min 1.5 ENET1_RX_DV}] -add_delay set_input_delay -clock enet_rx_clk_2_5_virt -min 1.5 ENET1_RX_DV}] -clock_fall -add_delay # Set Output Delay set_output_delay -clock enet_tx_clk_125 -min -0.5 ENET1_TX_EN}] -add_delay set_output_delay -clock enet_tx_clk_125 -max -clock_fall 0.5 ENET1_TX_EN}] -add_delay set_output_delay -clock enet_tx_clk_125 -max 0.5 ENET1_TX_EN}] -add_delay set_output_delay -clock enet_tx_clk_125 -min -clock_fall -0.5 ENET1_TX_EN}] -add_delay set_output_delay -clock enet_tx_clk_25 -min -0.5 ENET1_TX_EN}] -add_delay set_output_delay -clock enet_tx_clk_25 -max -clock_fall 0.5 ENET1_TX_EN}] -add_delay set_output_delay -clock enet_tx_clk_25 -max 0.5 ENET1_TX_EN}] -add_delay set_output_delay -clock enet_tx_clk_25 -min -clock_fall -0.5 ENET1_TX_EN}] -add_delay set_output_delay -clock enet_tx_clk_2p5 -min -0.5 ENET1_TX_EN}] -add_delay set_output_delay -clock enet_tx_clk_2p5 -max -clock_fall 0.5 ENET1_TX_EN}] -add_delay set_output_delay -clock enet_tx_clk_2p5 -max 0.5 ENET1_TX_EN}] -add_delay set_output_delay -clock enet_tx_clk_2p5 -min -clock_fall -0.5 ENET1_TX_EN}] -add_delay # Set Clock Groups set_clock_groups -exclusive -group -group -group -group -group -group -group -group -group -group # Set False Path set_false_path -from set_false_path -to set_false_path -setup -rise_from enet_tx_clk_125 -fall_to enet_gtx_clk_125 set_false_path -setup -fall_from enet_tx_clk_125 -rise_to enet_gtx_clk_125 set_false_path -hold -rise_from enet_tx_clk_125 -rise_to enet_gtx_clk_125 set_false_path -hold -fall_from enet_tx_clk_125 -fall_to enet_gtx_clk_125 set_false_path -setup -rise_from enet_tx_clk_25 -fall_to enet_gtx_clk_25 set_false_path -setup -fall_from enet_tx_clk_25 -rise_to enet_gtx_clk_25 set_false_path -hold -rise_from enet_tx_clk_25 -rise_to enet_gtx_clk_25 set_false_path -hold -fall_from enet_tx_clk_25 -fall_to enet_gtx_clk_25 set_false_path -setup -rise_from enet_tx_clk_2p5 -fall_to enet_gtx_clk_2p5 set_false_path -setup -fall_from enet_tx_clk_2p5 -rise_to enet_gtx_clk_2p5 set_false_path -hold -rise_from enet_tx_clk_2p5 -rise_to enet_gtx_clk_2p5 set_false_path -hold -fall_from enet_tx_clk_2p5 -fall_to enet_gtx_clk_2p5 set_false_path -fall_from enet_rx_clk_125_virt -rise_to enet_rx_clk_125 -setup set_false_path -rise_from enet_rx_clk_125_virt -fall_to enet_rx_clk_125 -setup set_false_path -rise_from enet_rx_clk_125_virt -rise_to enet_rx_clk_125 -hold set_false_path -fall_from enet_rx_clk_125_virt -fall_to enet_rx_clk_125 -hold set_false_path -fall_from enet_rx_clk_25_virt -rise_to enet_rx_clk_25 -setup set_false_path -rise_from enet_rx_clk_25_virt -fall_to enet_rx_clk_25 -setup set_false_path -rise_from enet_rx_clk_25_virt -rise_to enet_rx_clk_25 -hold set_false_path -fall_from enet_rx_clk_25_virt -fall_to enet_rx_clk_25 -hold set_false_path -fall_from enet_rx_clk_2_5_virt -rise_to enet_rx_clk_2_5 -setup set_false_path -rise_from enet_rx_clk_2_5_virt -fall_to enet_rx_clk_2_5 -setup set_false_path -rise_from enet_rx_clk_2_5_virt -rise_to enet_rx_clk_2_5 -hold set_false_path -fall_from enet_rx_clk_2_5_virt -fall_to enet_rx_clk_2_5 -hold # Set Multicycle Path set_multicycle_path -from enet_tx_clk_125 -to enet_gtx_clk_125 -setup -start 2 set_multicycle_path -from enet_tx_clk_25 -to enet_gtx_clk_25 -setup -start 2 set_multicycle_path -from enet_tx_clk_2p5 -to enet_gtx_clk_2p5 -setup -start 2 # Set Maximum Delay set_max_delay -from enet_gtx_clk_125 -to 20 set_max_delay -from enet_gtx_clk_25 -to 20 set_max_delay -from enet_gtx_clk_2p5 -to 20 # Set Minimum Delay set_min_delay -from enet_gtx_clk_125 -to 0 set_min_delay -from enet_gtx_clk_25 -to 0 set_min_delay -from enet_gtx_clk_2p5 -to 0
To RoyalOpino :
Maybe you can try the tools modelsim and Eclipse IDE to test your TSE works well or not .
kindly regards
To Mr. RoyalOpino
--- Quote Start ---
--- Quote End ---
May I interpret that you succeeded using your TSE ?
To Mr. fdsa
--- Quote Start ---
core dumped...
with the same result 2:
Code:
r1: c026ec90 r2: c0354000 r3: c0354000 r4: c0354000
r5: 00000001 r6: 00000000 r7: 00000000 r8: 00000000
r9: 00000008 r10: 00000171 r11: c035aacc r12: c0356a3c
r13: c0356a40 r14: ffffffe4 r15: c020d81c
ra: c026f520 fp: deadbeef sp: c025ef9c gp: deadbeef
ea: c026f614 estatus: 00000000
Unaligned access from kernel mode, this might be a hardware
problem, dump registers and restart the instruction
BADADDR 0xdeadbf0f
cause 7
op-code 0xb800283a
--- Quote End ---
The core dumped contents are same for both 'nios2-terminal < linux.initramfs.srec' and 'nios2-download -g zImage' ? In my circumstances, 'nios2-download' which is using 'JTAG Debugger' will not work well.
And it's better for us to make a new thread and discuss these things.
Kazu
--- Quote Start ---
To Mr. RoyalOpino
--- Quote End ---
Yes I did :) Thank you very much :cool:
sorry for reopening this thread. But it is not possible for me opening a new one and I have the same issue.
I am working with Quartus V14.1 and running Linux Yocto/Angstrom
Linux is booting and loading altera_tse driver.
But it doesn't recognise the tse_interfaces.
On boot up the following error message shows up: altera_tse c0010000.ethernet: resource s1 not defined.
(c0010000 is the base address of the tse_interface)
I didn't find any information about what to add to the xml files for generating the right dtb file.
As much as possible I followed the instructions from: http://rocketboards.org/foswiki/projects/alterasoctriplespeedethernetdesignexample
But the dtb generation is in quartus 14.1 other than in quartus 14.0
Where do I get the information what to add in the xml files?
Can you tell me, what to add?
thanks in advance,
Fabian
I think I have a problem which was here solved, so I hope the right people will read it...
I try to get tse working.
Installed is Quartus V14.1 and I work with the cyclone V.
I followed the instructions of rocketboards: http://rocketboards.org/foswiki/projects/alterasoctriplespeedethernetdesignexample
My problem is the difference of the quartus versions. So I can't take the dtb of the example. I think my one has another look.
My Linux which boots, is Yocto Angstrom kernel 3.10.
at boot up it says:
altera_tse c0015000.ethernet: resource s1 not defined
c0010000 / c0015000 are the base addresses of the tse-IPs.
Where do I get the information, what to add to the xml files for dts/ dtb generation?
I feel like searching the whole web, but nowhere I get answers...
Thanks in advance,
Fabian
