If someone like me wants to run uCLinux on a Nios2 but the fpga must not be a bga type then the biggest fpga available is EP2C20 with QFP 240 pins. That one can be handsoldered http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/tongue.gif (Done that several times before)
To have a lot of memory a would like to include sdram and of course a compact flash. as i would like to get rid of the cfi as the fpga will boot from epcs i asked myself if it could be possible to have only fpga + sdram + a big epcs + cf. after an AS configuration from the epcs nios could boot from epcs. now my question has anybody done this ? booting uCLinux from epcs. but not the whole uclinux. i think of a smal bootloader like lilo (grub under debian) that loads the rest from a compact flash card that can't be big enough :-) Regards MichaelLink Copied
Hi Michael,
> booting uCLinux from epcs. but not the whole uclinux. i think of a smal bootloader > like lilo (grub under debian) that loads the rest from a compact flash card that > can't be big enough You can use u-boot in such a design ... as it supports CF as well as epcs. If your epcs is large enough, you could fit the entire kernel ... u-boot can load, decompress, and boot a gzip/bzip kernel image (same goes for CF of course). Currently, I load u-boot from epcs and then boot a gzipped kernel image (~520 KB) either from parallel flash, a tftp server, or an NFS server. Same goes for the cramfs filesystem (which gets stuffed into SDRAM as well). Regards, --Scott- Mark as New
--- Quote Start --- originally posted by smcnutt@Feb 22 2006, 04:43 PM hi michael,
> booting uclinux from epcs. but not the whole uclinux. i think of a smal bootloader
> can't be big enough
you can use u-boot in such a design ... as it supports cf as well as epcs. if your
and boot a gzip/bzip kernel image (same goes for cf of course).
currently, i load u-boot from epcs and then boot a gzipped kernel image (~520 kb)
either from parallel flash, a tftp server, or an nfs server. same goes for the cramfs
filesystem (which gets stuffed into sdram as well).
regards,
--scott
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12890)
--- quote end ---
--- Quote End ---
Related to this, what are the advantages of using U-boot? I mean, Altera seems to have included a nice little boot copier that copies code from either CFI or EPCS to RAM and then boots, along with their flash programming utility. So to boot a kernel from EPCS, it should be as simple as downloading it to the config device and pointing to the altera boot copier.
Are there any advantages of U boot?- Mark as New
--- Quote Start --- originally posted by jdhar@Feb 28 2006, 01:46 AM related to this, what are the advantages of using u-boot? i mean, altera seems to have included a nice little boot copier that copies code from either cfi or epcs to ram and then boots, along with their flash programming utility. so to boot a kernel from epcs, it should be as simple as downloading it to the config device and pointing to the altera boot copier.
are there any advantages of u boot?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12981)
--- quote end ---
--- Quote End --- I boot from EPCS with the Altera boot copier and it works perfectly (Only with Quartus 5.1 and NiosII 5.1, the 5.0 versions had a bug which made it VERY slow). But if you want more control, load the kernel over the network, change parameters, choose a different kernel each time you boot etc. you need u-boot. I personally don't need it since I just use one kernel which I stored in EPCS. But the Altera bootcopier gives you zero flexibility.
I gotcha, makes sense. Do you know why Alteras flash programmer doesn't verify the contents of the EPCS when it programs? It just says "Did not attempt to verify device contents, leaving target processor paused"... when programming the EPCS.
Hi jdhar,
The Altera boot copier is a bare-bones crt0 implementation. It does exactly what you need it to do ... in only a handful of instructions ... nothing more. u-boot however, is a full-featured boot-loader, not just a "a nice little boot copier". In addition to the features wgoossens mentioned, u-boot also supports the following: - Command line interface via JTAG/UART. - Full epcs support read/write/program/protect. - Serial port download using kermit. - File download via Ethernet using TFTP and/or NFS. - Scripting (scripts can be run automatically at startup). - Flash programming (e.g. download your file via NFS, then program into your flash). - BOOTP/DHCP client support. - Memory read, write, fill, compare and tesing (several test flavors available). - RARP - Support for JFFS2, CRAMFS, DOS, etc. (including multiple partitions). - Support for SPI, MMC, CompactFlash, etc. The list goes on ... but you get the picture ... if all you need is crt0 -- use the Altera boot-copier. If you want (or need) to do more than that you can use u-boot ... or redboot ... or something similar. In any case, I highly recommend you give u-boot (and/or redboot) a test drive. There are many features you may find very handy ... and there's lots of code you can hoist into your own loaders as well. Regards, --Scott- Mark as New
--- Quote Start --- originally posted by smcnutt@Feb 28 2006, 09:33 AM hi jdhar,
the altera boot copier is a bare-bones crt0 implementation. it does exactly what you
a full-featured boot-loader[/b], not just a "a nice little boot copier". In addition to the features wgoossens mentioned, u-boot also supports the following: - Command line interface via JTAG/UART. - Full epcs support read/write/program/protect. - Serial port download using kermit. - File download via Ethernet using TFTP and/or NFS. - Scripting (scripts can be run automatically at startup). - Flash programming (e.g. download your file via NFS, then program into your flash). - BOOTP/DHCP client support. - Memory read, write, fill, compare and tesing (several test flavors available). - RARP - Support for JFFS2, CRAMFS, DOS, etc. (including multiple partitions). - Support for SPI, MMC, CompactFlash, etc. The list goes on ... but you get the picture ... if all you need is crt0 -- use the Altera boot-copier. If you want (or need) to do more than that you can use u-boot ... or redboot ... or something similar. In any case, I highly recommend you give u-boot (and/or redboot) a test drive. There are many features you may find very handy ... and there's lots of code you can hoist into your own loaders as well. Regards, --Scott <div align='right'><{post_snapback}> (index.php?act=findpost&pid=12988) --- Quote End --- [/b] --- Quote End --- Excellent info smcnutt; I believe the reason I didn't give Uboot a try before is because I saw a lot of board-specific stuff (meant for the Altera Eval boards), while I mostly work in custom hardware. I will admit that I didn't look in that much detail, so I could have missed it, but I will search around and give it a try. There's no such thing as too many options in my book http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
