I'm using uClinux from nios2-linux-20090730 and I was stuck triying to manage a simple PIO from a device driver, until I noticed that autogenerated nios2.h file does not enable peripheral adresses bit 31 to '1' in order to bypass cache. Does anyone know the trick to generate a suitable nios2.h with correct no-cache adressess. thanksLink Copied
ioremap_nocache()
thanks dsl
