I was trying to run uClinux on a Altera DE1 Board development board. I started by trying to use "DE1 SD Card Audio.sof" and "ZImage DE1 SD Card Audio v0.6", as described on the following page. I could see the system booting through nios-terminal when I did this. http://www.alterawiki.com/wiki/try_out_uclinux#for_de1_dev_board Next, I tried to build the system myself to achieve the same. I used "Quartus II 12.1 Web Edition" to build by sof file as described by Mahdi Hafezi, on following YouTube video. https://www.youtube.com/watch?v=rxlyezof0rs Next, I downloaded the Virtual Machine available from below URL, and used the toolchain included in that VM. I still used the instructions as described by Mahdi Hafezi. ftp://ftp.altera.com/outgoing/nios2-linux/32-bit_snapshot_vm_2012-04-16.zip I did get a zImage from this process and I could use "nios2-download -g zImage" to download the image to the board. Also the verification stage was ok after the download. However, when I used the command "nios2-terminal" I could not see the system booting. Basically there was no output at all. If I left the terminal open for a couple of minuets I did get some random characters on the terminal. I also tried connecting to the board's serial port while running "nios2-terminal" command, but nothing appeared on the serial port terminal as well. I was wondering if I'm doing something incorrect here, and wanted to ask if some cone could kindly guide me in the right direction. Thanks in advance for your kind assistance.Link Copied
Topic Options
