uClinux on Altera DE1 Board
I was trying to run uClinux on a Altera DE1 Board development board. I started by trying to use "DE1 SD Card Audio.sof" and "ZImage DE1 SD Card Audio v0.6", as described on the following page. I could see the system booting through nios-terminal when I did this.
http://www.alterawiki.com/wiki/try_out_uclinux#for_de1_dev_board
Next, I tried to build the system myself to achieve the same.
I used "Quartus II 12.1 Web Edition" to build by sof file as described by Mahdi Hafezi, on following YouTube video.
https://www.youtube.com/watch?v=rxlyezof0rs
Next, I downloaded the Virtual Machine available from below URL, and used the toolchain included in that VM. I still used the instructions as described by Mahdi Hafezi.
ftp://ftp.altera.com/outgoing/nios2-linux/32-bit_snapshot_vm_2012-04-16.zip
I did get a zImage from this process and I could use "nios2-download -g zImage" to download the image to the board. Also the verification stage was ok after the download. However, when I used the command "nios2-terminal" I could not see the system booting. Basically there was no output at all. If I left the terminal open for a couple of minuets I did get some random characters on the terminal.
I also tried connecting to the board's serial port while running "nios2-terminal" command, but nothing appeared on the serial port terminal as well.
I was wondering if I'm doing something incorrect here, and wanted to ask if some cone could kindly guide me in the right direction.
Thanks in advance for your kind assistance.
