Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
uart code
What does the following code do?
case(SW[3:0])
4'b0000: UART_TXD = RS422_1_TX;
4'b0001: UART_TXD = RS422_2_TX;
4'b0010: UART_TXD = RS422_3_TX;
4'b0011: UART_TXD = RS422_3_TX;
verilog challenged:oops:
Highlighted
Hi:
This is an 16 to 1 multiplexer or mux. Based on the 4-bit selection term SW, the output is connected to the input where SW matches the case term 4'b0000, 4'b0001 etc.
So if SW = 4'b0010, the output UART_TXD = input RS422_3_TX.
Highlighted
Thank you very much!
Highlighted
I am using an eval board. I am trying to communicate with a PC via the RS232.
Can I just use the switches to send an 8 bit signal? It doesn't let me just assign the switches as an array to the UART TX?
What am I doing wrong?
Highlighted
I'm trying to build a vhdl uart too. I think that the TX is only one bit long because it is a signal you have to modify according to your baudrate.
