The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
12489 Discussions
uart instead of the jtag_uart_0
Gerhard56
I have a sample, which uses a uart.
So I didn't add a jtag_uart_0 and now I get errors when generating the BSP. Any idea how to redirect a jtag-uart-0 to a uart?
With best regards
Gerhard
BoonBengT_Intel
Hi @Gerhard56,
Thank you for posting in Intel community forum, hope this message find you well and apologies for the delayed in response.
I if understand correctly the situation, perhaps the following steps should help to change the jtag-uart-0 to a uart 1) right click on nios ii project, click Index --> Rebuild 2) With that in the BSP editor updated uart should be should be showing up, and click on the Generate to ensure updated.
Please do try out and let us know if it helps.
Best Wishes
BB
Gerhard56
Hi BB,
I found out how to switch between the UARTs, so this case can be closed.
With best regards and stay healthy
Gerhard
BoonBengT_Intel
Hi @Gerhard56,
Noted on your feedback and good to know that it is working now, we would be closing the thread.
Best Wishes
BB
