12604 Discussions
uboot problem about "bootm" command
Please please please help me.
I am almost crazy.
The following is the problem description.
Now, I have a DE0 board, uClinux kernel, NIOSII processor, and u-boot.
The version of uClinux kernel is uClinux-dist-20110603.
The NIOS II version is 10.1 and quartus II version is 10.1.
The u-boot version is u-boot-2011.06.
I want to download the .sof file to DE0 board and then boot kernel.
I have the three way to achieve the goal. I fail in one of them which is used the "bootm" command.
First, I don't use the u-boot to boot kernel. (OK:))
Directly download the kernel to the memory and then boot kernel.
(I use the compressed image kernel which is not .gz file but through "misc.c" )
--- Quote Start ---
[NIOS2_EDS] nios2-download -g zImage
[NIOS2_EDS] nios2-terminal
--- Quote End ---
Second, I use the u-boot's "go"command to boot kernel. (OK:))
Directly download the kernel to flash by using "flash programmer tool" of NIOS IDE. And then I copy the image kernel from flash through "cp.b" command. Finally, I key in "go" command booting kernel.(I use the uncompressed image kernel which is not through "misc.c")
--- Quote Start ---
==>cp.b 02400000 01800000 400000
==>go 01800000
--- Quote End ---
Third, I use the u-boot's "bootm" command to boot kernel. (FAIL:cry::)
(I use the compressed image kernel which is not .gz file but through "misc.c")
1. I create the uImage through the "mkimage" tool.
The following is the settings
--- Quote Start ---
mkimage -n 'linux- 2.6' -A nios2 -O linux -T kernel -C none -a 0x01800000 -e 0x01800040 -d zImage uImage_18
--- Quote End ---
--- Quote Start ---
mkimage -n 'linux- 2.6' -A nios2 -O linux -T kernel -C none -a 0x01800000 -e 0x01800000 -d zImage uImage_1D
--- Quote End ---
The following is board information
--- Quote Start ---
==> bdinfo
mem start = 0x01800000
mem size = 0x00800000
flash start = 0x82400000
flash size = 0x00400000
flash offset= 0x00000019
ethaddr = (not set)
ip_addr = 0.0.0.0
baudrate = 1 bps
--- Quote End ---
2. bootm command
A. copy uImage_18
--- Quote Start ---
==>cp.b 02400000 01800000 200000
==>bootm 01800000 -
# # Booting kernel from Legacy Image at 01800000 ...
Image Name: linux- 2.6
Image Type: NIOS II Linux Kernel Image (uncompressed)
Data Size: 1457595 Bytes = 1.4 MiB
Load Address: 01800000
Entry Point: 01800040
Verifying Checksum ... OK
XIP Kernel Image ...
OK <-----------------------------(stuck here.......)
--- Quote End ---
B. copy uImage_1D
--- Quote Start ---
==>cp.b 02400000 01D00000 200000
==>bootm 01D00000 -
# # Booting kernel from Legacy Image at 01D00000 ...
Entry Point: 01800000
Loading Kernel Image ...
--- Quote End ---
Could you give me "any any any" suggestions. I need them.
Please please help me.
God bless you.
Thank you very much.
Please do not post your question multiple times.... just choose a forum and put it there
--- Quote Start ---
--- Quote End ---
Sorry, I would not do that.
Excuse me,could you give me some suggestion about this problem.
