Hi everyone,
I been trying to port uboot for stratix EP1S40 board for the last 2 months...but seems like I have no luck...I already posted my issues couple of times.....but no luck so far. I have a very simple task...all I want is to load uclinux from SDRAM address 0x01000000 with uboot ........so that ....the board runs uclinux when power is applied........without running "nios2-download -g vmlinux" everytime. The vmlinux is created using std_1s40.ptf file that comes with nios-II development kit IDE. I downlaod the source code of u-boot-1.1.2........and just use the pk1c20 board files as reference............. to create u-boot.bin for stratix professional edition board EP1S40. I couldn't see any major difference between these 2 boards. I am not a hardware person ............... just try to follow the logic. Anyhow......I am now stuck here with u-boot.bin, u-boot and u-boot.srec....files...don't know how to download the u-boot to stratix EP1S40 board using altera's utility programs that comes with nios-II IDE kit. I am getting an error messages.....while using *.sof files that comes with nios-II IDE kit.......while running "niso2-flash-programmer" utility program. I am not sure if I am following the right path.......while using the pk1c20 base code. Is anyone can guide........how to program flash memory using nios-II SDK utilities. thanks,Link Copied
Have you read nios ii flash programmer user guide (http://www.altera.com/literature/ug/ug_nios2_flash_programmer.pdf)?
Hi haq,
> I been trying to port uboot for stratix EP1S40 board for the last 2 months...but > seems like I have no luck... What exactly is the problem you are having with u-boot? > I already posted my issues couple of times.....but no luck so far. And each time you have received a reply :-) But you never provided any feedback. > I have a very simple task...all I want is to load uclinux from SDRAM address 0x01000000 > with uboot ........so that ....the board runs uclinux when power is applied........without > running "nios2-download -g vmlinux" everytime. If all you want is to run uclinux when power is applied, you don't need u-boot. > Anyhow......I am now stuck here with u-boot.bin, u-boot and u-boot.srec....files...don't know > how to download the u-boot to stratix EP1S40 board using altera's utility programs that > comes with nios-II IDE kit. 1. start your terminal software. If your using the jtag uart, run nios2-terminal. Otherwise, startup your terminal emulation software (e.g. Hyperterminal). 2. make sure u-boot is working. Run: $ nios2-download -g u-boot If you don't get the u-boot command prompt, then you didn't port u-boot correctly. > I am getting an error messages.....while using *.sof files that comes with nios-II IDE > kit.......while running "niso2-flash-programmer" utility program. If you post the errors, someone might be able to help. Regards, --Scott
