win7+virtubox+fedora10+quartus11.0
nios2gcc2008... nios2linux2008... i use the DE2-V1.5 demostration ,DE2_NET and use it to run uclinux when using the default configuration for kenel, zImage can be generated . and i download sof and zImage, it's OK ... but nios2-terminal command has problem . the uClinux logo can be seen . but sash don't. and the message it give is : Init:Missing TERMTYPE field in inittabLink Copied
I have received the same exact error, v1.5.
Unfortunately, haven't figured it out yet, it seems to be something wrong with the linux kernel itself running that /etc/rc script? I'm using uClinux-dist-20071107, which kernel are you using?
