uclinux sopc2dts xml
I want to add devicetree to my uclinux system.
http://www.alterawiki.com/wiki/devicetree
In the step
java -jar sopc2dts.jar -t dts -i path_to_your_system.sopcinfo -o path_to_your_system.dts
I got error
Component lcd_display of class altera_avalon_lcd_16207 is unknown
Then I read something fromhttp://sopc.et.ntust.edu.tw/pipermail/nios2-dev/2011-march/005030.html
Seemed like I need to create a sopc_components_*.xml file to describe the unrecognized components. But I don't know how, and I didn't find any tutorial either.
Can anyone give me any advice?
kindly help
The alterawikihttp://www.alterawiki.com/wiki/sopc2dtsdoes not mention how to add a user-specified xml file.
One component has so many parameters, where can I find them all?
I have the same problem, buddy. Mr Yang !
You can find the what you need in http://www.mjmwired.net/kernel/documentation
Could you make it ?You can contact me, I come from Shandong
