12603 Discussions
unable to link an executable image
I'm jus triying to compile and link a simple "hello world" application with gcc
nios2-linux-gnu-gcc (version 4.1.2)
but gcc does not reconize -elf2flt parameter as we can see in the compiler output:
jordi@debian:$ nios2-linux-gnu-gcc hello.c -o hello.exe -elf2flt
/home/jordi/projects/vdm-1/system/current/nios2-linux/toolchain-mmu/x86-linux2/bin/../lib/gcc/nios2-linux-gnu/4.1.2/../../../../nios2-linux-gnu/bin/ld: warning: cannot find entry symbol lf2flt; defaulting to 0000137c
The output file remains in elf format instead of desired flat.
please help, I'm realy stuck at this point :(
thanks
You need to use objcopy to convert the file format.
thanks dsl
I've tried $nios2-linux-gnu-objcopy -i srec hello -o binary hello.exe -s
And I've got hello.exe file that heads with:
00000000 2F6C 6962 2F6C 642E 736F 2E31 0000 0000 /lib/ld.so.1....
00000010 0400 0000 1000 0000 0100 0000 474E 5500 ............GNU.
00000020 0000 0000 0200 0000 0600 0000 1500 0000 ................
00000030 0300 0000 0800 0000 0700 0000 0600 0000 ...............
It doesn't seem a binary flat executable file.
So where is the trick ?
Did I a mistake using objcopy ?
thanks
You've told objcopy the input file is 'S-records' - not surprising it doesn't DTRT!
Your elf file probably contains multiple sections (depending on what is in the linker script) that get loaded to different addresses. You'll need to extract these separately. 'objdump -p' will list the program sections (which are the ones you probably want), use the -j parameter to objcopy to select the section.
thanks dsl
I found that a little complicated.
I think, I've better to use an older toolchain (gcc version 3.4.6)
that accept -elf2flt parameter.
I run nios2-linux-gnu-gcc hello.c -o hello2 -elf2flt and it works.
I wonder why gcc 4.1.2 doesn't accept that.
thanks
I can't see where gcc 3.4.6 supports it, the copy I have doesn't.
Possibly something is using that parameter to set the OUTPUT_FORMAT outside the linker script - but I can't see a command line parameter to ld that would do that.
For flexibility (and to know what is actually being done) it is best to run objcopy yourself.
OK dsl
I'll follow this way
Thankyou
--- Quote Start ---
thanks dsl
thanks
--- Quote End ---
Hi, I am experiencing same problem.. I see that you have switch to older version of GCC. could you give me some instruction how safely remove the GCC and install the older one?.. I have tried this before but was not able to.. Sorry I have still much to learn in this linux
Hi, Lanzones
I finally opted for using and old uClinux distribution (Linux version 2.6.19-uc1 from www.uclinux.org) and using also an old toolchain gcc version 3.4.6. You can get the tool from
http://www.alterawiki.com/wiki/binarytoolchain
you can decompress the archive http://www.niosftp.com/pub/gnutools/nios2gcc-20080203.tar.bz2 in any place you wish (i.e /opt/nios2-toolchain)
You have to put in the 'path' the path to binaries in your bashrc file
i.e:
PATH_TOOLCHAIN_NIOS2=/opt/nios2-toolchain/build_nios2/staging_dir/bin/
PATH=$PATH:$PATH_TOOLCHAIN_NIOS2
export PATH
to compile my old version of linux I have to do something like this:
M_ARCH=nios2nommu
M_SYSPTF=$M_DIR_BASE/ptf/NIOS.ptf
# toolchain (builroot)
M_TOOLCHAIN=/opt/nios2-toolchain/build_nios2/staging_dir/bin/nios2-linux-
# hardware assign
make ARCH=${M_ARCH} CROSS_COMPILE=${M_TOOLCHAIN} vendor_hwselect SYSPTF=${M_SYSPTF}
# compile
This is valid for old uClinux dist so you will have to tune for your distribution.
good luck
Thanks jofasa,
got it...
with this solution, the elf2flt function will work properly.I try to do the DEBUG Apps " nios2-linux-uclibc-gcc -g hello.c -o hello -elf2flt" again and it should work this time..
do you think this is also the reason why I couldnt run properly the
make gcc elf2flt gdb-host on building the toolchain?
some clarification.. ALL of below should be all in my .bash_profile.. correct?
export PATH
M_ARCH=nios2nommu
Hi Lanzones
In .bashrc you have to put only the path to binaries toolchain
all the rest is just a script stuff to compile the kernel.
You have to keep on mind the toolchain prefix, in my case is "nios2-linux-",
so the compiler call is nios2-linux-gcc. In your case it seems to be "nios2-linux-uclibc-". We have different toolchains, so you should modify the path I give you as exemple in order to have correct binaries path in your toolchain.
thanks.. I have it working..
just for curiosity,, I have downloaded the toolchain and I gone in each directory coz I am trying to find /build_nios2/staging_dir/bin/ from your setting.. Couldnt find it...
Is this something that you have put or generated?. BTW do I need to make the toolchain by MAKE?...
I've got the my toolchain yet compiled from a colleague, so I didn't to make it.
So, if you can't find the binaries, you should first make the toolchain project.
