Hi all,
We got this error if we use the (small) Newlib C library: -- start -- Error pure.o * In function `__cxa_pure_virtual': undefined reference to `fwrite' pact_sb line 0 -- end FYI: we do remove/comment all printf statements How can we get rid of this error? Any one helps? Regards, Kwok WongLink Copied
--- Quote Start --- originally posted by kwokwong@Dec 29 2004, 10:51 AM hi all,
we got this error if we use the (small) newlib c library:
-- start --
error pure.o * in function `__cxa_pure_virtual': undefined reference to `fwrite' pact_sb line 0
-- end
fyi: we do remove/comment all printf statements
how can we get rid of this error?
any one helps?
regards,
kwok wong --- Quote End --- The reference is made in the file pure.cc: --start --# ifdef _GLIBCPP_HAVE_UNISTD_H# include <unistd.h># define writestr(str) write(2, str, sizeof(str) - 1)# ifdef __GNU_LIBRARY__ /* Avoid forcing the library's meaning of `write' on the user program by using the "internal" name (for use within the library). */ /*# define write(fd, buf, n) __write((fd), (buf), (n))*/# endif# else# include <cstdio># define writestr(str) std::fputs(str, stderr)# endif extern "C" void __cxa_pure_virtual (void) { writestr ("pure virtual method called\n"); std::terminate (); } -- end Who can tell what this funtions does and/or which ohter (libray) funtion requires this functions?
The function __cxa_pure_virtual() is a placeholder function inserted automatically by the compiler. It is used whenever you declare a pure virtual function in a base class (that is, a function that won't have an implementation provided:
class an_abstract_base_class
virtual void do_something() = 0;
Since you can't create instances of an_abstract_base_class, you shouldn't be able to call the non-existant function an_abstract_base_class::do_something(). The compiler still needs to create a vtable (virtual function dispatch table) for abstract classes (those with one or more pure virutal methods like an_abstract_base_class), so it has to put something in the vtable entries corresponding to pure virtual functions: it uses __cxa_pure_virtual(). In properly written code __cxa_pure_virtual() should never get called. If it does somehow get called it's a signal that something has gone seriously wrong with your code. So, to eliminate the undefined reference error you have two choices: Either remove all pure virtual functions from you project, or provide your own version of __cxa_pure_virtual() that doesn't use facilities which aren't available on your hardware platform (e.g. just go into an infinite loop flashing an LED).
Thanks for the reply.
I'll look for all unimplemented pure virtual methods.
