i want to download my design by usb blaster.but there's no usb blaster in my quartusII5.0. So i want to know where can i get the install file and if there's something that i should pay attention to during the installing process?
thx regard leon tsaoLink Copied
I'm not sure what you mean. There are no physical USB-Blasters supplied with Quartus but the drivers should be there (look for a drivers directory as part of your Quartus install).
no ,i can't find it in my altera\quartus50\driver\usb blaster directory. I think there must be some thing wrong with my software. So i want to install it separately.
THX all the same! if some kind friend have the install file ,looking forward to sending to my email box.thank you! my Email: leon_tsao@56.com- Mark as New
Here is a link to USB Blaster installation information.
http://www.altera.com/literature/lit-devkits.jsp (http://www.altera.com/literature/lit-devkits.jsp) There is no installation file other than the driver that is installed in the QuartusII directory, Example Directory, C:\altera\quartus50\drivers\usb-blaster If you are using Windows, windows should detect the presents of a new USB device, if it does then you must follow the instructions that are in the above link to the user guide for installation. If windows does not detect a new device, then you may have something wrong with you USB port or Windows drivers to your USB port. Good Luck, Brandon
